Author: Subject: where to get long throttle cable
smart51
posted on 17/3/08 at 01:41 PM Reply With Quote
I need a throttle, about 3m long. Where can I get one from?
iank
posted on 17/3/08 at 01:47 PM Reply With Quote
In rough order of locost
MR2 or MGF
Hillman Imp Sport
Tandem bike
Boot/fuel filler cap release cables from the scrapyard maestro/montego or rover 200 will do the job.
Anonymous
Lars
posted on 17/3/08 at 01:53 PM Reply With Quote
CBS do an 11ft cable
worX
posted on 17/3/08 at 01:57 PM Reply With Quote
Could try these guys?
http://www.zoomkarts.com/products.asp?categoryID=8
speedyxjs
posted on 17/3/08 at 02:00 PM Reply With Quote
Jag ones are pretty long.
RazMan
CBS do a 4 metre one - how much longer do you need?
Raz
smart51
posted on 17/3/08 at 02:14 PM Reply With Quote
Wow. Plenty of choice. I never thought of boot release cables. Cheers.
posted on 17/3/08 at 02:24 PM Reply With Quote
look at VWP - they sell the outer and inner cable per metre and nipples to fit.
Danozeman
posted on 17/3/08 at 04:37 PM Reply With Quote
Id go to the local bike shop and buy a length of bowden cable, sheath and 2 nipples 9ooooh err.
Dan
kb58
posted on 18/3/08 at 12:59 AM Reply With Quote
An advantage of a push-pull throttle cable is that if it sticks, you might be able to pull the pedal up. Not a big chance of it happening, but worth considering.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Kaspa
posted on 18/3/08 at 07:29 AM Reply With Quote
thats something i definitly wouldnt recomend, thats what i did on my car and it almost cost me a major, throttle jammed on at 200pluss ks going into a 2nd gear cnr you should have seen the laundry bill.
theres to much friction in a bowden or push bike brake cable and even with two return springs it was sticking, replaced it with a Webber throttle cable and its now as smooth as silk.
the boot release cable is also a good alternitive to a high priced gen artical, as i found out after i bought mine.
Kaspa
understeer= when you hit the wall front first
oversteer=when you hit the wall back first
HP= how fast you hit the wall
Torque= how far the wall moves when you hit it
Sven
posted on 18/3/08 at 11:22 PM Reply With Quote
Bicycle brake cables work well for a throttle cable and they come in pretty long lengths.
-Steve
"Lightheadedness through quickness"
Syd Bridge
posted on 19/3/08 at 06:46 PM Reply With Quote
http://www.speedycables.com/
