xxx
posted on 18/3/08 at 07:23 PM |
Xflow Sump Change
Hey guys. Unfortunately I need to change the sump on my 1.3 xflow. However the two bolts at the rear end are hidden by the bell housing.
I did not build my locost but Im hoping to learn some car mechanics by working on it myself.
Basically Im planning on hiring an engine crane and splitting the box from the engine just enough to get at the bolts.
Is this the best way of doing things? What will I encounter when split, will it just be one shaft? I prosume Ill need to support the gearbox also?
Thanks for your help, just trying to get an idea of what Im letting myself in for and what could cause difficulties?
tjoh84
posted on 18/3/08 at 07:34 PM |
i leant on my xflow when i swaped 1300 for 1600 all i can say it took a lot of red ball and my mate to get the gear box back on good luck
nib1980
posted on 18/3/08 at 07:39 PM |
yep it's the only way to do the rear seal properly.
I split mine and rebuilt it on my own, just make sure to support the gearbox too when you split it, and check the nose bearing on the end of the
gearbox
nib1980
posted on 18/3/08 at 07:40 PM |
where are you located, maybe some one can help?
I have done that job - It is possible, but not a pleasant experience!
Lying flat on my back with very little room in any direction... in the end I swore that I'd never do it again. The engine and gearbox would come
out together before I try that job again!
posted on 18/3/08 at 07:53 PM |
It can be done in situ but not nice , easier to pull the engine out.As already said support the box. IF you take the clutch and flywheel off to
replace the rear seal make sure you centralise the clutch properly otherwise you will have problems getting it back in.
D Beddows
posted on 18/3/08 at 08:00 PM |
Take the engine out - you can just about get those two bolts out with the right wobble bar extension on the end of your wrench BUT getting them back
in (especially with a new sump gasket in place) redefines the phrase 'b*stard of a job'
[Edited on 18/3/08 by D Beddows]
posted on 18/3/08 at 08:51 PM |
If I have to do it again I may leave off the gaskets, and use some of the newer instant gasket goo. Hermatite make some good stuff that may stop oil
leaks from the sump better than gaskets. Also if you can lay the engine on its side it may be easier to fit the sump?
LukeSheffield
posted on 18/3/08 at 10:14 PM |
I did it, but it did require, a decent set of tin snips to cut the clutch cover plate either side (was refitted by using the two bottom holes in
bell-housing). Then i got one of those cheap flexi arm things and with a small socket and mini ratchet thing. I did it on the road and so
couldn't really drop the engine out.
