Author: Subject: front suspension rose joints
Miks15
posted on 24/3/08 at 04:46 PM Reply With Quote
Is it possible to use a rose joint instead of a top ball joint? will it give enough vertical movement?
This is what i need to make and a rose joint would be easier
TGR-ECOSSE
posted on 24/3/08 at 07:16 PM Reply With Quote
Formula 2 stock cars use rose joints top and bottom
They are available from McGill Motorsports Thats where i borrowed the picture from
Give him a call he should be able to help you out. (His number is on his site)
Ronnie
Miks15
posted on 24/3/08 at 07:29 PM Reply With Quote
cheers ronnie that helps alot
Puk
posted on 31/3/08 at 07:53 AM Reply With Quote
Rose joints on a road car
If you are looking to use your car on the road then you might want to be careful about using rose joints. They don't have the longevity of a ball joint.
Before you judge a guy, walk a mile in his shoes. Then when you judge him, you're a mile a way and you've nicked his shoes.
