Author: Subject: tdi prob / anyone got a vag com?
ned
posted on 25/3/08 at 11:10 AM Reply With Quote
Bit of a long shot I know but I'm having problems with my tintop (vw tdi not starting from cold).
Anyone near Guildford got a vag com and willing to help/read my ecu?
Or got any suggestions for my problem?
Basically vw pd tdi not starting when cold. Initially suspected glow plugs but apparantly more likely a glow plug relay or temp sensor fault following a search on a vw forum.
http://uk-mkivs.net/forums/p/187141/1222073.aspx#1222073
cheers,
Ned.
beware, I've got yellow skin
iceman26
posted on 25/3/08 at 11:17 AM Reply With Quote
what car is it in and what year
ned
posted on 25/3/08 at 11:19 AM Reply With Quote
w reg/2000 vw bora 1.9 tdi se pd 115
iceman26
posted on 25/3/08 at 11:21 AM Reply With Quote
at vw the normal fault was with the temp sender
[Edited on 25/3/08 by iceman26]
ned
posted on 25/3/08 at 11:33 AM Reply With Quote
thanks iceman.
just rung the nearest dealer and they have the temp sensor in stock, relay they weren't sure which one and there's a choice of £20 or £80 ones apparantly!
cheers,
Ned.
gregs
posted on 25/3/08 at 12:00 PM Reply With Quote
have a search around on here you should get an answer pretty quickly... best of luck.
Slightly off topic, but have a look in your fuse box and make sure the relay with 109 on it is grey and upsidedown - this is the main power relay and the cause of 'tdi sudden death' not one to be experienced on the motorway - £15 for the 'good' one.
K999NNY
posted on 25/3/08 at 03:43 PM Reply With Quote
A few of the mebers on www.seatcupra.net have vag.com. Try on there, sonebody might be able to help you.
ned
posted on 25/3/08 at 03:46 PM Reply With Quote
thanks guys, got the temp sensor to fit tonight.
also managed to order a retro fit cruise control kit today! apparantly all mk4 tdi's have it as standard, you just need the stalk, loom and someone to unlock the funcitonality in the ecu to get it working!
cheers,
Ned.
ps for anyone interested changed the sensor last night and it started on the button this morning
[Edited on 26/3/08 by ned]
