Author: Subject: Rebore of 1600 crossflow
mattjhunt
posted on 29/3/08 at 07:15 PM Reply With Quote
I've got an old 1600 711m crossflow engine I'm bringing back to life. Thinking I should get it rebored (to 1760cc?).
How much would this cost, and any ideas who to go to in the Oxfordshire area?
Also, is this a good idea? All crossflows on ebay seem to have been done....
cheers
[Edited on 29/3/08 by mattjhunt]
posted on 29/3/08 at 07:33 PM Reply With Quote
Suspect with it bored out to give you 1760cc you will end up with porous/ weak cylinder bores . IIRC the block that will bore out that big is the AX block? which tend to be megabucks. My 711m block is bored out 30thou and still puts out 127BHP and will pull from 1500 rpm in 5th gear. The popular engine is the so called 1700 which is 90thou oversize and gives 1690cc Check the casting number on the side of the block , it will be T ?? The higher the T number the thicker the bore walls are supposed to be T 20 being the highest number
RichieW
posted on 29/3/08 at 07:43 PM Reply With Quote
I'd rebore it the minimum you can get away with so in future if the cylinders wear again you can freshen it up with a further rebore and rebuild. If you rebore it out to the max on the first go you are left with nowhere to go other than having it relinered.
gazza285
posted on 29/3/08 at 08:35 PM Reply With Quote
I've got a T22
Thinking about it
posted on 29/3/08 at 08:45 PM Reply With Quote
I have been quoted £70 plus vat by a local guy who does a lot of classic car engine rebuilds. And £50 plus vat at an engine re conditioners I have no experience of. Prices are for bore and hone. It's the cost of the pistons and rings which is the expensive bit.
hissingsid
posted on 29/3/08 at 09:39 PM Reply With Quote
Try Oselli in Witney. Seem to be fair prices and local to you I guess!
They were tinkering with Crossflows since they came out!
I'll be sending my 1300 there when I get round to engine rebuilding!
nitram38
posted on 29/3/08 at 10:17 PM Reply With Quote
Any of you guys used 1300gt pistons in a 1600?
I remember rebuilding my 1600 crossflow in my anglia (originally built by Ron Harris racing) after I blew it up a couple of times.
The 1300 piston has a smaller cup and therefore increases the compression ratio.
Gives a bit more power with relatively little cost.
gazza285
posted on 29/3/08 at 10:29 PM Reply With Quote
Smaller cup, but a heavier piston because of it ok for mild performance gains.
nitram38
posted on 29/3/08 at 10:40 PM Reply With Quote
I think Ron used to modify them and rebalance them
posted on 30/3/08 at 12:42 AM Reply With Quote
I've got a T22
I did say IIRC but my memory is not what it was.
gazza285
posted on 30/3/08 at 12:47 AM Reply With Quote
And I said .
brynhamlet
posted on 30/3/08 at 06:18 AM Reply With Quote
Talk to Newark Engines at Sutton on Trent.
Unit 2 Gardners Court, Old Great North Rd, Sutton-on-Trent, Newark, Nottinghamshire NG23 6QS
Tel: 01636 822614
He built my engine -
Formula Ford bottem end, i.e. 1800cc, balanced crank, lightened flywheel, etc. Gas flowed head converted to unleaded.
He has all the facilities to do what you want within your budget.
I got an excellant engine, built from scatch which is seriously quick from them.
Oh and when you look at their workshop facilities and talk to them you will undersand that they can deliver
[Edited on 30/3/08 by brynhamlet]
thepest
posted on 30/3/08 at 06:49 AM Reply With Quote
If of any help, I used the fiat 2 Liter Pistons, they are flat top not a bowl. CC of 1740. I know that it may sound strange to use a flat head and a flat piston but it surprisingly works on the crossflow really well. You would need to re-bore the connecting rod gudgeon pins to suit the fiat piston.
The fiat piston is light and I have been running 10.5:1 comp with no problems.
I'm not a pioneer in this field, here in malta all crossflow tuners do this.
jollygreengiant
posted on 30/3/08 at 11:17 AM Reply With Quote
Yep I'd agree with this. When I rebuilt my 1600 into a screamer in '79/80, I went to 1662cc by using Powermax Lotus twin cam piston. Had these machined down flat, then deck heighted the block for a 10.5/11.0:1CR and used a flat full race head with a mild race cam. All the bottom end lightened and balanced. With twin 40's and a piper ladder rocker gear, all nestle in a Mk1 Cortina. With a 3.7 diff it would pull clean in top right up to 8k RPM. 30 to the gallon on a run and very slightly quicker than a 2.8I capri.
posted on 30/3/08 at 12:12 PM Reply With Quote
I have a rebored x-flow, and I do like it very much. but I wouldn't spend significant money on it any more.
If it fails for any major reason then I'll probably whip it out (ooer!) and stuff a Zetec in there, or maybe a 4-AGE if I can find a cheap enough one (The Toyota 4-AGE is a reasonably modern engine that's not a lot bigger than the x-flow, and a lot more powerful straight out of the box).
There is the law of diminishing returns to consider...
david walker
posted on 30/3/08 at 08:11 PM Reply With Quote
Quote
"Formula Ford bottem end, i.e. 1800cc, balanced crank, lightened flywheel, etc. Gas flowed head converted to unleaded."
So that would be an illegal FF1600 then eh? Dodgy outfit that talks ......!
FF1600 engines are 1600cc, are not gas flowed and don't have lightened flywheels!
How do you get a 1600 X'Flow out to 1800cc? - In LOCOST fashion? Using largest available std type pistons, ie +90thou, they go to 1690cc, often referred to as 1700.
+1mm Lotus piston at 83.5mm is about all it's SAFE to take a std type 711m block out to.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
posted on 30/3/08 at 10:31 PM Reply With Quote
I bought a brand new set of +90 1300 pistons and rings, and then found out my 1600 (711M) block had been linered and wasn't capable of being bored out.
[Edited on 30/3/08 by MikeRJ]
