Author: Subject: rattling
bracey
posted on 30/3/08 at 01:35 PM Reply With Quote
rattling
what could cause a loud rattling just above tickover and on lift off in a 1800 vauxhall ohc ,checked pullys etc but sounds internal ,no loss of poke and driveability
thanks
richard
Mansfield
posted on 30/3/08 at 01:52 PM Reply With Quote
Is it the same clutch in / clutch out?
bracey
posted on 30/3/08 at 02:26 PM Reply With Quote
better check that
bracey
posted on 30/3/08 at 05:54 PM Reply With Quote
no difference clutch in or out ???
bracey
posted on 31/3/08 at 07:34 PM Reply With Quote
thought better check oil very low infact very very very low so am now thinking knackered big ends etc
what other engine choices do i have that will fit getrag box from manta
cheers richard
david walker
posted on 31/3/08 at 08:41 PM Reply With Quote
Because it's pronounced when you lift off it could well be failed big ends. The rattling is caused by the pistons hitting the cylinder head - a function of loads of clearance at the big end!
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
NS Dev
posted on 31/3/08 at 09:13 PM Reply With Quote
vauxhall XE 16v, the obvious choice, or, if you are on a tighter budget (not that they are expensive) then get a 2.0 8 valve vauxhall lump out of a late 8 valve cav sri, they are 130hp as std and bulletproof (as long as you keep the oil level right!) they made them with 8 valvers up to '93 iirc
bracey
posted on 2/4/08 at 05:23 PM Reply With Quote
10 points to dave walker ,yep big ends ,good news is have aquired spare engine so hopefully not of road long
just my luck though ,just getting sunny here
