Author: Subject: How to...? paint aluminium
xico_ze54
posted on 3/4/08 at 12:52 PM Reply With Quote
could someone tell me the right product(s) to aply over aluminium to make good adherence? international brands... please, specific products?
I'm in this stage of building:
http://www.viseudesign.com/Sevenesque-28.htm
and want to make a nice job with that future blue bonet.
thks
Mole
posted on 3/4/08 at 01:01 PM Reply With Quote
Acid etch primer then ordinary paint I believe but someone will be along to correct. I'm maily posting to say it would be a shame to paint that bonnet.
MikeCapon
posted on 3/4/08 at 01:09 PM Reply With Quote
This is what that bonnet wants/needs
[img][/img]
www.shock-factory.co.uk
worX
posted on 3/4/08 at 01:12 PM Reply With Quote
You would use an Acid Etch Primer. (as said above)
I was just searching Google to find you an international brand when I came across this advice on a LandRover forum:
PAINTING ALI ADVICE!
There was a paint called ACID#8 that appears to be pretty good and international.
If you spray on the etch primer, even though it's eaten into the metal and primed it for paint, if you rub through you need to spray it again...
Have you considered getting the bonnet anodised? It might cost a bit, but would look pretty damn cool!
Bluemoon
posted on 3/4/08 at 01:18 PM Reply With Quote
I have used ACID#8 very good stuff can recommend.
Dan
Mr Whippy
posted on 3/4/08 at 01:25 PM Reply With Quote
Image deleted by owner
sorry but I agree, it's just too nice to paint. Poll
[Edited on 3/4/08 by Mr Whippy]
the_fbi
posted on 3/4/08 at 01:26 PM Reply With Quote
Acid #8 is from u-pol, available in both a Powercan (large 450ml aerosol) and as a 1L tin.
I've used it previously on ally and it works great.
Datasheet here.
http://www.u-pol.com/countries/en/downloads/tds/acid8.pdf
speedyxjs
posted on 3/4/08 at 01:32 PM Reply With Quote
F*ing good stuff that! I used that on the chrome on the tin top yesterday and made a MASSIVE difference
posted on 3/4/08 at 01:46 PM Reply With Quote
Acid #8 sure is good. Evil stuff though. Wear goggles if you're spraying outside
posted on 3/4/08 at 02:10 PM Reply With Quote
paint = excess weight. Colin will be truning over in his grave ......
Mr Whippy
posted on 3/4/08 at 02:33 PM Reply With Quote
ever seen the original 7's chassis
scary how lightly built it was, looked like bicycle frame tube
bimbleuk
posted on 3/4/08 at 03:19 PM Reply With Quote
An alternative which I've used is Etchweld by Bilt-Hamber laboratories
Puk
posted on 3/4/08 at 03:51 PM Reply With Quote
Spining Colin
I suspect the whole Locost thing is giving Chunky Chapman a high grave RPM already, let alone whether the bonnets are painted! He tried to to kill the 7 off with the Europa, sold the design to that mug from Caterham.
Before you judge a guy, walk a mile in his shoes. Then when you judge him, you're a mile a way and you've nicked his shoes.
zilspeed
posted on 3/4/08 at 05:03 PM Reply With Quote
Another vote for not painting it here.
Miks15
posted on 3/4/08 at 05:05 PM Reply With Quote
one more for leaving it unpainted, would look brill polished up
RazMan
posted on 3/4/08 at 05:14 PM Reply With Quote
One tip for painting alluminium - rub it down with Scotchbrite to take the shine off it before priming with acid etch.
Raz
Confused but excited.
posted on 3/4/08 at 05:47 PM Reply With Quote
But having said all that. I too agree it would look awesome polished.
Fred W B
posted on 3/4/08 at 07:19 PM Reply With Quote
Enough about paint already - how did you (or who) make those lovely louvers?
Fred W B
tks
posted on 3/4/08 at 07:31 PM Reply With Quote
Back to polishing then...
xico_ze54
posted on 3/4/08 at 09:39 PM Reply With Quote
Fred W B
see the pics of that machine in my website.
back to polishing/painting... My car will be blue in top, aluminium in the sides.
I don't like - as several pics I've seen - the nosecone and scuttle coloured and bonet without colour.
for me the colour who start in in nose will finish in the scuttle, passing by the bonet.
it's a choice! and I've studied very much that color scheme 5 years (yes) ago.
cheers & thanks all for coments about alu painting
xico_ze54
posted on 3/4/08 at 09:42 PM Reply With Quote
hey TKS, you live some 200km away from my town
RK
posted on 3/4/08 at 11:14 PM Reply With Quote
Polished alu looks dumb and cheap. But, hey, that's just me. I was told to sand with 220 grit prior to painting, but scotchbrite would do the same job. Gives the paint something to stick to apparently.
robertst
posted on 3/4/08 at 11:30 PM Reply With Quote
thats exactly what i'm doing, i'm also planning on painting the bonnet blue...
excellent choice of colour!.
Tom
