Author: Subject: Adhesive number plate
Monkeybasher
posted on 15/4/08 at 07:35 PM Reply With Quote
After searching on here I believe my adhesive number plate is illegal....ish. So will this fail the MOT then? The spacing and fonts etc are all correct.
If it will fail an MOT I will have to put my hard normal number plate on, but for obvious reasons I don't want to peel the stick on one off so I will have two front plates, do you think this will pass ok?
gregf27
posted on 15/4/08 at 07:37 PM Reply With Quote
had one on mine , passed no problems!!
JUD
posted on 15/4/08 at 07:41 PM Reply With Quote
Find a friendly MOT centre... somebody that is not a jobsworth.
MK Indy Blade
ReMan
posted on 15/4/08 at 07:43 PM Reply With Quote
It's what the passenger seat is for
Monkeybasher
posted on 15/4/08 at 07:46 PM Reply With Quote
Ye I did have, but the mechanics moved, rubbish
I Never used to have to put fog light on or worry about emissions etc.
I'll give it a bash with just the stick on plate and see what happens.
Cheers guys
[Edited on 15/4/08 by Monkeybasher]
Monkeybasher
LOL
owelly
posted on 15/4/08 at 07:51 PM Reply With Quote
The reflective bit needs to be BS approved. Just velcro the hard plate on for the MOT and keep it with the vehicle should the BiB have a whinge.
http://www.ppcmag.co.uk
eccsmk
posted on 15/4/08 at 07:57 PM Reply With Quote
i had a chat with the lad who does my mot's
he said as far as mots go as long as the number plate is easy to read its passable
the policeman who pulled me on my way home from the mot said that altho the mot tester could pass it he couldn't let me get away with it!!
worX
posted on 15/4/08 at 08:04 PM Reply With Quote
As someone mentioned above, just temp fit the hard one ASWELL and then both parties are happy - even happier when the hard one falls off two mins after you pull back into your garage
UncleFista
posted on 15/4/08 at 08:08 PM Reply With Quote
The "new" MOT rules are very strict where number plates are concerned, they must be absolutely bog standard.
Within a few days of the new rules, they were suspended[1] and any 'plate that can be read must be passed. Dunno whether that's changed once again or not...
[1] Due to a large number of new-ish vehicles failing the test.
Tony Bond / UncleFista
RazMan
posted on 15/4/08 at 09:45 PM Reply With Quote
Common sense comes into it here - as long as you are seen to try and conform without taking the wee then most testers and plods will turn a blind eye.
Just stay away from non reflective backgrounds, fancy fonts and silly sizes
Raz
Howlor
posted on 16/4/08 at 09:22 AM Reply With Quote
Exactly right I think. If you try to comply and don't take the wee then you will be fine.
