bjw970s
| posted on 16/4/08 at 02:43 PM |
LOCOBLADE Spring Ratings
Can anyone advise on the spring poundage they use for a BEC?
One of my more experienced racing friends was surprised by the spring rate on my newly refurbished car.
It started life as a crossflow and was converted to Bike prior to me buying it - my mate suspects that the springs weren't revised as part of
the conversion
Any pointers welcomed.
As someone else once said 'LOCOST my Ar**
Crazy Eddie
| posted on 16/4/08 at 03:02 PM |
My megablade came with 200 fronts and 150 rears.
I find this good. However, others have said it may be a bit low and that they would go for higher.
Down to driving styles and how you would like the car to handle really but at least this gives you one option.
Eddie
www.EdwardsSchoolOfMotoring.co.uk
For online shopping that earns you money : Ei42.com
bjw970s
| posted on 16/4/08 at 03:37 PM |
Thanks,
Driving style is a point well made.
My mate runs a suzuku TL1000 in his selfbuilt 'Fletcher hornet' his are very soft as he tends to take a heck of a lot of curb when
racing.....
Having only sprinted mine so far, I am not keen to change anything just yet! just after some pointers.
As it has been corner weighted etc - I will leave as is with the shock asborber settings tweeked, till after Brands Hatch in 2 weeks
ChrisGamlin
| posted on 16/4/08 at 04:11 PM |
Is it live axle or IRS / De Dion?
Although you can get a rough guide from others, don't forget that you can only really compare against other cars that are IDENTICAL suspension
geometry wise as yours, by that I mean the same wishbones, the same pickup locations on the chassis etc etc, because a 1" movement of a damper
pickup for example could mean a 25-50lb difference in spring requirement for the same effective springrate due to the different angles etc.
Chris
mark chandler
| posted on 16/4/08 at 08:01 PM |
It also depends on you wishbones, with book bones the shock sits ~ 1/3 in on the bone so this acts as a lever so a 180lb spring on the road will act
like a 120lb spring. Also the angle has some affect.
On mine at the front the shock points at the lower ball joint so no real leverage at the front but this is at an angle, mine are 230lb springs which
probally equates to 200lb in reality.
On the rear they are upright but 1/4 way in on the IRS bone , although 150lb springs the actual road rate will be nearer 120lb.
Regards Mark
[Edited on 16/4/08 by mark chandler]
bjw970s
| posted on 17/4/08 at 10:37 PM |
Thanks for all the points.
I am running a live axled, Stewart Taylor chassis I can post some pics of it - I have loads of the re-build!
I will run it at Brands and decide whether to go further..........
