Author: Subject: what engine for boost
oadamo
posted on 22/4/08 at 08:09 PM Reply With Quote
if you was to buy a bike engine to turbo for a long term project what engine would you buy tp start off with.
adam
imp paul
posted on 22/4/08 at 08:37 PM Reply With Quote
worX
posted on 22/4/08 at 08:39 PM Reply With Quote
imp paul
posted on 22/4/08 at 09:03 PM Reply With Quote
and you would need lots of ££££££££££
posted on 22/4/08 at 09:18 PM Reply With Quote
There's a book out there (can't remember the name of it) specifically about slapping blowers and turbos on bike engines....
Gives links to all the standard installations as well as DIY advice....
But yes, the Busa turbo install is a quite well trodden path....
Crazy Eddie
posted on 22/4/08 at 09:45 PM Reply With Quote
Natuarally depends on budget.
I would say Blade engine because if / when it goes pop the engines are easy to come buy and cheaper to replace but I only earn £5k a year
www.EdwardsSchoolOfMotoring.co.uk
For online shopping that earns you money : Ei42.com
Volvorsport
posted on 22/4/08 at 10:27 PM Reply With Quote
a car engine
www.dbsmotorsport.co.uk
getting dirty under a bus
graememk
if you ask the taxman i earn even less lol
welderman
posted on 23/4/08 at 07:15 AM Reply With Quote
i agree with paul
Thank's, Joe
I don't stalk people
imp paul
posted on 23/4/08 at 06:35 PM Reply With Quote
hi joe hope all is good with you i still have my imp at mb and now am missing it lots it cost me £160 to take it there and same to bring it back
worX
posted on 23/4/08 at 08:48 PM Reply With Quote
Thats the only problem with Malc of MB Customs...
He's virtually in another country! I mean everything else is perfect, his knowledge and ability - Spot on! His service and attitude - Spot on! His willingness to help and advise people and not care about making a penny from it - Spot on!
Top Bloke!
oadamo
posted on 23/4/08 at 10:59 PM Reply With Quote
zx12r with gt35r twin scroll turbo
what sort of power will you get out of it when done.
adam
imp paul
posted on 24/4/08 at 06:19 AM Reply With Quote
approx 500 to 550 bhp at 20 psi of boost
[Edited on 24/4/08 by imp paul]
posted on 24/4/08 at 11:21 AM Reply With Quote
If you're gonna stick a turbo on it, I too would go for a Busa.
Phil
Minicooper
posted on 25/4/08 at 11:48 AM Reply With Quote
Paul,
What has been done internally to it to produce this sort of power?
What boost power will it run normally?
sucksqueezebangblow
posted on 25/4/08 at 01:38 PM Reply With Quote
Take a look at http://www.holeshot-racing.co.uk/ for ideas.
imp paul
posted on 25/4/08 at 08:12 PM Reply With Quote
OK here we go again parts are je pistons low comp ape billet cam pulleys schnitz racing valve springs Carrillo h beam drag spec con rods billet clutch basket billet cam chain tensioner kit balancer shaft removed 630cc injectors billet fuel rail dta engine ecu garret gt35r twin scroll turbo twin tial 38mm waste gates tial 50mm bov charge cooler aq mist water spray ape studs for the block and nuts cometic head gasket billet 360 swing sump aircraft spec con rod bolts MB customs manifold bosch 044 grp a fuel pump aromotive .8 fuel reg that's just of top of my head
[Edited on 25/4/08 by imp paul]
