dan__wright
| posted on 24/4/08 at 11:40 AM |
inboard brakes?
has anone put inboard brakes on an IRS 7?
what are peoples thoughts on this? should be a good unsprung weight saving, see it on ultima's and the zcars monte carlo.
shouldn't be too hard if you are using bolt in shafts?
find suitable discs you can put between diff and shafts and bolt through, holders for calipers and your sorted?
quite tempted to so this once im on the road.
FREE THE ROADSTER ONE…!!
PAUL FISHER
| posted on 24/4/08 at 11:46 AM |
Cooling may be a bit of a problem,they will be a bit out of the way of the airflow,either side of the diff,I think you would be hard pressed to notice
a difference on the unsprung weight advantage on the rear of a Indy,it would be a lot of work for little reward in my view.
Mr Whippy
| posted on 24/4/08 at 11:47 AM |
might be tempted to duct some cooling air to them
nitram38
| posted on 24/4/08 at 12:21 PM |
Probably will Sh*g the CV's out too
designer
| posted on 24/4/08 at 12:39 PM |
Cooling would be no problem for road use.
MustangSix
| posted on 24/4/08 at 12:43 PM |
Jag XKE, XJ6/12, XJS all had inboard rear discs. Big issues were not performance, but in serviceablity and heat.
The Jag brakes, esp the parking brake, can be a real PITA to service. And the heat was not a braking performance issue. It was the fact that it
caused increased temps on the carrier, cooking the seals and causing differential leaks.
Vented rotors and ducted air cures that issue.
MikeCapon
| posted on 24/4/08 at 12:50 PM |
My tintop has inboard front brakes and in spite of its ferocious neck-snapping performance they are splendid
[img][/img]
www.shock-factory.co.uk
| posted on 24/4/08 at 01:00 PM |
I've seen a Sierra back end with the disc's bolted between the drive shaft and output flange on the diff... should be easy to make a
caliper bracket there.
Maybe someone with a spare bolt on diff can evolve a locost upgrade???
sebastiaan
| posted on 24/4/08 at 01:06 PM |
HERE you go...
MikeCapon
| posted on 24/4/08 at 01:14 PM |
Very neat job. Bike calipers and discs. Plenty powerful and super light weight. Just the handbrake to worry about
dhutch
| posted on 24/4/08 at 01:30 PM |
2vc's have inboard breaks, when racing they tend to have large fins bolted to the calipers, and or ducted cooling or fans.
- It also gets interesting if the propshaft fails or comes undone! Seen that happen.
However it would indeed be possable and maybe as you say help reduce unspring mass.
Daniel
dan__wright
| posted on 24/4/08 at 02:42 PM |
i was thinking along the lines of bike brakes
Mr Whippy
| posted on 24/4/08 at 03:26 PM |
isn't that what is being used in Sebastiaan's link, only the center of the brake rotor is scratch made. Very impressive job.
dan__wright
| posted on 24/4/08 at 03:52 PM |
yep that is exactly what i had in mind!
it is very tidy and hope that if i do go ahead with it it comes out half as good
[Edited on 24/4/08 by dan__wright]
dan__wright
| posted on 24/4/08 at 03:59 PM |
would a single disc on the prop side of the diff be a no no? obv less to have do build etc but should be putting a lot of stress on the diff / drive
train i guess?
mark chandler
| posted on 24/4/08 at 05:49 PM |
Singke disc on the prop does not work as the lighter wheel starts to spin in the opposite direction. It also overloads the halfshafts and diffs.
Landrovers have handbrakes on the prop, drag it on before stopping all sorts of banging and broken half shafts.
Regards Mark
erwe
| posted on 24/4/08 at 06:35 PM |
That was my old racer, sold it last year.
The braking was very good, I did use air duct in the passengers place for cooling.
The only problem I had was the mounting of the diff to the chassis, I made it far too light.
Because the acceleration and brake forces came together at the diff mountings I should have used much heavier material.
But that should not be a problem when you build it heavier, the whole car was a little too weak for normal street use.
You could add a Wilwood handbrake caliper for SVA.
Liam
| posted on 24/4/08 at 07:57 PM |
That's beautiful work, erwe! But yeah perhaps the diff mounts look a little flimsy for taking braking loads too (although it looks like you
picked up the front mounts of the diff too through those tunnel tubes - is that right? They're normally ignored). Did you actually get a
failure?
When you say the whole car was a little too weak what do you mean? The chassis looks excellently designed and made from a stiffness point of view.
Was it more issues with 'minimalist' bracketry? Anyway great work
Another reason a brake disc on the prop isn't a great idea is the prop is spinning, say, 3.5 times faster than the driveshafts - instant melted
brakes!
Liam
| posted on 28/4/08 at 03:10 PM |
brakes!
LR have drum brakes on the rear and the drum on the prop/transmission is the handbrake. It is unlikley you would or indeed should slap on the
hand brake whilst moving at any reasonable speed.
There is an aftermarket disc brake conversion for the handbrake - search X-Eng if you want to know more.
| posted on 30/4/08 at 08:58 PM |
Regards Mark
Too right transmission brakes are nasty.
| posted on 30/4/08 at 09:04 PM |
You could use the complete rear axle assembly from a Lotus Elite/Eclat/Excel. Inboard drum brakes at least on the two early models -- not sure about
the Excel.
Inboard brakes work particularly well on a De Dion axle --- no torque reactions.
| posted on 30/4/08 at 09:10 PM |
Oil leaking on the rear discs was a fact of life on Jags --- horrible brakes to work on no room and you had no vision of what you were working on.
Dropping the complete axle subframe on a Jag wasn't an option unless your were forced into it. The Jag rear axle assembly was so heavy.
Rover used very similar inboard discs on the P6 but at least it was easy to lower the diff to change the pads.
