Author: Subject: remote oil filter plate
phongshader
posted on 29/4/08 at 12:18 AM Reply With Quote
I'm looking for a plate to fit on a 2.3 Duratec similar to this
dry sump
dry sump
but with an outlet as well
[Edited on 29/4/08 by phongshader]
CairB
posted on 29/4/08 at 07:28 AM Reply With Quote
If you could get one for a dry sump you may be able to tap the other port in.
You could try Titan or Pace for the plate.
Alternatively, Raceline do a plate that mounts the spin on filter straight out and you can get oil cooler sandwich plates that provide the 2 ports.
I am looking at doing this at the moment for mine.
Colin
Doofus
posted on 29/4/08 at 08:47 AM Reply With Quote
I made one from a block of Ally and tapped it with 1/2BSP tap then screwed in 2 male to male adapters from Think Auto. It worked out a lot cheaper than a Raceline filter adapter. I'll grab a photo at lunch.
Paul.
phongshader
posted on 30/4/08 at 01:12 AM Reply With Quote
Paul.
That's what I ended up doing last night
