Author: Subject: Alloy Sizes
Adam
posted on 29/4/08 at 07:11 PM Reply With Quote
Alloy Sizes
I know this has probably been asked a million times before but i don't semm to be able to find the right answer when i do a search.
I'm lookng at buying some alloys for my MK , lookng at 15". What offset do i need and what width tyres? All standard wings etc etc, sierra running gear.
Cheers in advance
Adam
eccsmk
posted on 29/4/08 at 07:13 PM Reply With Quote
7" wide rims et35 should do the trick
LINK
[Edited on 29/4/08 by eccsmk]
delboy
posted on 29/4/08 at 07:19 PM Reply With Quote
your MK build manual states 15x6.5J ET38(offset 38mm). They spec tyres as 195x50x15. At least thats what the most current one says, although I've seen one which says 15x6J ET 38, but it's form an older version of the build guide.
snapper
posted on 29/4/08 at 07:46 PM Reply With Quote
To go wider than recomended means that the outside edge of the wheel could protrude outside the wings, if you have enough backspace then you can restore the correct outside edge position by increasing the ET by half the extra wheel width, i.e +13mm(1/2 inch) increase ET from 38 to 45.
Big problem with Sierra based running gear is the large ET built in, you can always get bigger front wings but often the rears need modifying.
I eat to survive
I drink to forget
Crazy Eddie
posted on 7/5/08 at 12:05 AM Reply With Quote
I have these if you like:
http://www.locostbuilders.co.uk/viewthread.php?tid=88640
However won't pass SVA if that's what you need them for as the spokes are shaped behond arches.
Eddie
PS Anyone know what offset I need for 13" 6J ?
www.EdwardsSchoolOfMotoring.co.uk
For online shopping that earns you money : Ei42.com
jabbahutt
posted on 7/5/08 at 07:21 AM Reply With Quote
I fitted 195 tyres on ET38 alloys and they fill the rear arches nicely.
Hope that helps
Nigel
