Johneturbo
posted on 11/5/08 at 07:23 PM |
lower bone
Hey all, thought i'd post here as i might not be the only one to do this.
i've fitted my lower wishbone with the bracket for the pushrod at the bottom, like i've seen in other build diarys.
i went for the first test drive today on a airfield. but lower spherical bearing pulled out past the circlip. with the car landing on its
belly/nose
the only thing i can think of is the lowerbone is upside down. how have you guys fitted yours? is it like mine in the pic (it's not a great pic)
with the pushrod bracket at the bottom, which mean the circlip is taking all the weight of the car
![](/galpreviews/a741582-Front view.jpg) ![Rescued attachment Front view.jpg](/gallery/a741582-Front view.jpg) Rescued attachment Front view.jpg
amalyos
posted on 11/5/08 at 07:46 PM |
Lower wishbone should be like this.
![](/galpreviews/a741601-Front Lower Wishbone.JPG) ![Rescued attachment Front Lower Wishbone.JPG](/gallery/a741601-Front Lower Wishbone.JPG) Rescued attachment Front Lower Wishbone.JPG
http://stevembuild.blogspot.com
bassett
posted on 11/5/08 at 09:54 PM |
I assumed it was how you had yours as from the manual it looked like the pushrod was on the underside.
worX
posted on 12/5/08 at 05:12 AM |
Thats not how it is in the manual though.
Not that I am saying you're wrong because I also thought it made more sense that way round, but I just followed the manual...
GeorgeM
posted on 12/5/08 at 10:06 AM |
I agree with amalyos.
The build manual does show the pushrod mount
under the bone, but this puts all the weight
on the circlip.
Turn the bones over.
GeorgeM
Johneturbo
posted on 12/5/08 at 04:45 PM |
Ok guys
I turned the bones over so the circlip is facing down. one thing i've noticed thou is the lower bones don't sit horizontal, it sits lower
than the chassis because the pushrod is on top, thats with about 6 threads on the coilovers showing.
worX, i've just had a look at your build pics of Tims car, seems there are two types of front lower bones then!.
stuart_g
posted on 12/5/08 at 10:02 PM |
John, mine are the same as yours with the pushrod mount on the bottom. It's going to be a real b'stard to change them over now. I'm
sure the build manual shows them this way, have you spoken to MNR about it?
Did you keep the bones on the same side and did you end up with the top bone rod end behind the bottom bone?
TimC
posted on 13/5/08 at 05:19 AM |
Knowing Marc, probably more likely 11 types of front wishbone.
Johneturbo
posted on 13/5/08 at 05:48 PM |
Hey Stu, you might still be ok is your circlip under or ontop? if its ontop then you need to turn them over. i didn't swap sides just turned
them over.
only thing now is the lower bone does sit below horizontal.
i'm just glad it fell out when it did and not on the road. the only damage is the nose is rashed and cracked
ps i've not spoken to mnr
[Edited on 13/5/08 by Johneturbo]
stuart_g
posted on 13/5/08 at 06:18 PM |
John, if there are two versions can you not get the version which has the circlip underneath from MNR? If your lower bones are not horizontal it
doesn't seem right according to the manual. I'll check mine and let you know.
Davey D
posted on 13/5/08 at 09:00 PM |
My lower bones have the pushrod mount underneath,and the circlip on top... its got me a little worried now after reading this.
I think we need to get Mark in here to clarify what is what
GeorgeM
posted on 13/5/08 at 09:14 PM |
can you not adjust the pushrods
to get the bones level??
GeorgeM
marc n
posted on 14/5/08 at 06:45 AM |
hi all
there are 2 different variants of wishbones, the wishbone uniball location in the bottom arm has been inspected by two independant engineers and
approved to run either way round, in fact my original car still runs with the clip at the top, as long as the circlip is fully engaged then there is
no problem running it either way round although most run as per stuarts pic
edit to add:- dont worry about the ride height implications as once the car has been used a bit the suspension will drop at least 20mm from where you
originally set it
cheers
marc
[Edited on 14/5/08 by marc n]
please email rather than u2u
chrismnrltd@btinternet.com
Syd Bridge
posted on 14/5/08 at 08:58 AM |
Two "independant engineers" may have approved that setup. (Must have bought their qualifications online. )
But tell me and the rest of us, what is the safest, and therefore the only, way to use that wishbone on the road.?
Syd.
marc n
posted on 14/5/08 at 10:32 AM |
the best way for sure is to have circlip below, my point was it has been approved for use either way round and has indeed been used both ways round
cheers
marc
marc n
posted on 14/5/08 at 11:25 AM |
to avoid confusion ref build manual im going to take it off line and try to update so there are clearer pictures and better wording in places and also
pictures relevant to the newer cars.
cheers
marc
Johneturbo
posted on 14/5/08 at 04:54 PM |
Ahh, so my car ended up on its belly (with a damaged nose) through no fault of my own? i thought it was because i had the lower bone the wrong way
round.
i'd recommend anyone that has it the same way i did, to turn them around.
stuart_g
posted on 14/5/08 at 09:09 PM |
I checked mine tonight and mine have the circlips on top. I don't know what to do now either. I have the lower bones level as it is as per
manual. IMHO it looks better with the pushrod mount on the bottom and with the bones the other way up looks like they are on upside down.
One thought is why can't the bearing carriers be welded on with the circlips on the bottom along with the pushrod mounts, surely this would solve
the problem.
I really need to know wether to turn the lower bones over or not.
If they have been approved for use either way up what are the chances of having both circlips not seated properly as in John's case?
Marc, In this pic you have the lower wishbones on with the pushrod mounts at the bottom, are the circlips on top?
![](/galpreviews/a743405-car3.jpg) ![Rescued attachment car3.jpg](/gallery/a743405-car3.jpg) Rescued attachment car3.jpg
marc n
posted on 15/5/08 at 09:15 AM |
yes my car has circlips on top and always has had that car is the same chassis ive always used but has gone through a few body colour changes, and two
years of use racing trackdays and road
in regards to chances of clip not seated this is the first one.
Going forward i would suggest for everyones piece of mind that every car should have the circlip mounted underneath and also that a thourough check is
done to ensure that the circlips are correctly seated,
the manual is a little ambiguos in this area as various drafts exist and in many places photos and descriptions are contradictory some of the photos
used our in fact builders own
If anyone has any doubts or is confused please feel free to contact us immediately and we can talk you through how to check and identify your setup
Saftey is paramount so if in doubt ask
best regards
marc
marc n
posted on 15/5/08 at 09:18 AM |
john regarding your nosecone damage please can you contact us with details / damage, and then we will resolve for you
cheers
marc
Johneturbo
posted on 20/5/08 at 09:25 PM |
An update to say thanks to mnr for resolving my misfortune![](/images//smilies/smile.gif)
finlay
posted on 22/5/08 at 01:31 PM |
this is a bit of a blow, i have fitted mine as per the manual with the circlip on top , it will be a right pain to switch them round,
what is everyone else doing ?
i am swaying towards just leaving them as is with the circlip on top as per manual
marc n
posted on 22/5/08 at 07:29 PM |
i would recommend that now one has lost its circlip it is better for piece of mind to flip over.
cheers
marc
gr8ging
posted on 23/5/08 at 08:22 PM |
What about the RT(outboard) theres no option to turn the bones over as the shock mount is on the top!!? So should we run with this risk of the circlip
popping out???
Weaseling out of things is what separates us from the animals.... except the weasel.
You couldn't fool your own mother on the foolingest day of your life with an electrified fooling machine!
marc n
posted on 26/5/08 at 09:15 AM |
i have drawn up a metal retaining spigot that goes over the circlip held in by 5 m5 bolts which should be available in approx 3 weeks time
cheers
marc
