Author: Subject: X FLow Piston Removal
hemibum
posted on 17/5/08 at 08:28 AM Reply With Quote
Hi, quick daft question. Can you remove the pistons from a x flow from the bottom? ie. past the crankshaft.
GazzaP
posted on 17/5/08 at 08:33 AM Reply With Quote
Hiya
I don't think you can all of the one s i have built i've removed from the top.
Gary
www.gmpmotorsport.co.uk
posted on 17/5/08 at 09:13 AM Reply With Quote
Take the head off and "lift " the piston and con rod out
Danozeman
posted on 17/5/08 at 09:16 AM Reply With Quote
Lift out from the top. Youd never fit them again from the bottom anyway so you have to take the head off regardless even if you could get them out the bottom.
Dan
hemibum
posted on 17/5/08 at 09:33 AM Reply With Quote
OK, Thanks. Didn't expect that I could. Just wanted to avoid lifting a twin cam head.
Fatgadget
posted on 17/5/08 at 01:05 PM Reply With Quote
Did you say Lotus Twin Cam?
Do yourself a favour mate. Pull the lump out and work on it on the bench should it have anything as serious as a damaged piston.
I am talking from painful past experience messing around with these engines.
posted on 17/5/08 at 04:39 PM Reply With Quote
Lotus Twincam dosen't suffer bodges -- take care.
If a Twincam needs a piston odds are it needs a full rebuild.
On a Twincam you are pulling the piston because of loss of compresion usual cause is bent valve(s) usually caused by exceeding the redline.
