Author: Subject: Is There A Problem with Service Pack 3 for XP
mad-butcher
posted on 30/5/08 at 08:28 PM Reply With Quote
Hi Guys
Is there a problem with service pack 3, for the past year or so my laptops been quite happily downloading upgrades, the other day I had a problem which necesitated using the full system recovery,format and reinstal, all went OK till it downloaded service pack 3, now it downloads upgrades but will not instal them (keeps saying some upgrades could not be installed) KB890830/KB894864 I've had to block them on the laptop cos I'm sick of the yellow upgrade button also getting error code OX800706BE It's more anoying than anything
Many Thanks
Tony
ch1ll1
posted on 30/5/08 at 08:42 PM Reply With Quote
i had nearly the same ,
downloaded it computer wouldnt restart !
rolled back, ok now
all i get now is when i open a screen on the net,
sometimes it will open and stay blank(white)
wont let me close it !
any body know how to sort that on out?
paul
posted on 30/5/08 at 09:10 PM Reply With Quote
rolled back, ok now
paul
Cant help anymore than to say reset your homepage (in Firefox - Tools/Options/Main) type in your new homepage: http://www.google.com or whatever you like
HTH - Steve
rf900rush
posted on 30/5/08 at 09:56 PM Reply With Quote
If you were selling Vista would you improve XP or make it worse with updates?
I leave mine set with no updates.
posted on 30/5/08 at 10:06 PM Reply With Quote
Considering MS will now supply a "downgrade" disk so owners of Vista Business and Ultimate can move to XP, it seems like even they are acknowledging that it doesn't suit everyone.
SP3 can offer up to 10% speed increase over an unpatched copy according to a few reviews.
Mad-butcher, try downloading the updates manually from the MS website and installing them, this has fixed similar issues I've had before.
viatron
posted on 31/5/08 at 07:34 AM Reply With Quote
SP3 has a known issue when installed on computer using an AMD CPU but has the intel CPU drivers present, a handy tool is available to check and resolve this issue before installing SP3. You can download it from:
XP SP3 Tool
posted on 31/5/08 at 07:42 AM Reply With Quote
rolled back, ok now
paul
It could be a few things most likely an IE7 issue or a tcp/ip stack issue --- with Xp it is really better to stay with IE6 or if you want tabbed browsing Firefox.
mad-butcher
posted on 31/5/08 at 09:22 AM Reply With Quote
cheers guys found the cure
http;/forums.microsoft.com/TechNet/ShowPost.aspx?PostID=3308206&SiteID=17
just go to c:\windows\system32 and find and register wups2.dll
to do that,right click on it and select open with then Choose Program and find
c;\windows\system32\regsvr32
if you choose to 'always use the selected program to open this type of file' then all you will have to do is double click on any dll to register it
once you have registered Wups2 all your problems will disappear
Thanks to a Gary o'Connor on that site for the info above
NOTE: this is only for the problem of XP with SP3 not installing updates.
Tony
joneh
posted on 31/5/08 at 09:41 AM Reply With Quote
XP SP3 Tool
This was on HP machines installed using the ISO.
iank
posted on 31/5/08 at 10:40 AM Reply With Quote
XP SP3 Tool
HP make machines with AMD and Intel CPUs depending on the model.
Anonymous
posted on 31/5/08 at 03:38 PM Reply With Quote
XP SP3 Tool
ISTR another couple of big Brands also affected --- I think Acer was one.
