New Topic New Reply
Author: Subject: pedal box, bushes?
Miks15
posted on 1/6/08 at 04:01 PM Reply With Quote
pedal box, bushes?
Ive started on my pedal box using roadster as a guideline ( need a hydraulic clutch and mine is slightly wider than the book in the footwell)
It says that it uses the acetal bushes in tube on the pedal. Only problem is i dont have the right size tube or the bushes.
Are the bushes realli necessary? I have some M10 bolts and tubes to fit which would be 100 times easier and quicker for me to fit. and i wouldnt have to but some tube and bushes etc so sticking locost. Is it ok to do it without the bushes?
cheers
Mix
posted on 1/6/08 at 04:13 PM Reply With Quote
Hi
I'd say yes with reservations...
The tube should be seamless, of an equivilent ID and I would lube the joint with a good quality anti sieze grease.
Regards Mick
Miks15
posted on 1/6/08 at 04:25 PM Reply With Quote
alternatively does anyone make just the pedals/bushes and tubes for a cheap price?
Mole
posted on 1/6/08 at 04:30 PM Reply With Quote
Not sure if its any help but I'm using PTFE for the bushes rather than acetal.
Miks15
posted on 1/6/08 at 04:31 PM Reply With Quote
anyone got any off cuts of the right size tube they dont need?
Kaspa
posted on 4/6/08 at 09:54 AM Reply With Quote
You can buy a balance bar from OBP and the tube comes with it. i have a spare but mail would cost more than its worth, other wise youd be welcome to it
cheers Kaspa
understeer= when you hit the wall front first
oversteer=when you hit the wall back first
HP= how fast you hit the wall
Torque= how far the wall moves when you hit it
posted on 4/6/08 at 05:03 PM Reply With Quote
cheers Kaspa
I believe the OP is talking about the pedal pivot bushes rather than a balance bar assembly.
A steel/steel bearing would probably work acceptably well for the limited movement and forces involved, though it's not generally good practice to use the bolt shank as a bearing surface.
New Topic New Reply
