dubstar_04
posted on 5/6/08 at 07:42 PM |
Locost Wishbones
I am after a set of front wishbones to suit the original book chassis.
Thanks,
Dan
Miks15
posted on 5/6/08 at 08:32 PM |
rally design do a set, 180 quid or sumfin like that if i memba correctly
austin man
posted on 5/6/08 at 09:11 PM |
think MK sportscars do an updated one the book ones can bend
winchman
posted on 7/6/08 at 08:33 AM |
I have a brand new set
Any thing else you need?
I am selling a whole car Half built with 95% of the parts to finish it
and its looking like I will brake it
I am in St.Helens Merseyside
07790546422
[Edited on 7/6/08 by winchman]
procomp
posted on 9/6/08 at 07:26 AM |
Hi Dan. After our conversation at Anglesey the weekend i gather you did not find Steve in the paddock.
But i have found his contact details.
Stephen Hills.
LRC Motorsports.
01733 352682 (mobile 07803 049712),
As i explained he supplies the parts you require and is in attendance at the race meetings with spare ones should you need. As regard the MK ones they
still have too many failure problems for use on a race car.
cheers Matt
dubstar_04
posted on 10/6/08 at 10:36 AM |
Thanks Matt.
Due to financial reasons I think I might make my own. What is the optimum wall thickness steel to use, 2mm? Also would you advise using round or
square section?
You say to create 5 deg castor by using 19mm offset.
Is there any benefit to this rather than simply oversizing the mounting brackets and using spacers to provide the correct castor?
Sorry for asking so many questions!!
Thanks,
Dan
dubstar_04
posted on 11/6/08 at 11:32 AM |
Does anyone have any experience with the above.
posted on 11/6/08 at 12:33 PM |
2mm wall should be plenty strong enough. Oversize brackets will hang off the chassis rail so might need some bracing unless you move the fu tube. Get
stuck in and don't over think it.
dubstar_04
posted on 12/6/08 at 06:58 AM |
Whats the opinion on using rectangular hollow section rather than circular hollow section?
It will be stiffer and have less deflection however will be slightly heavier.
Does anyone have any opinions of the benefits, and or short comings?
procomp
posted on 12/6/08 at 07:42 AM |
Hi Dan sorry forgot this thread was running ect. U2U sent.
Cheers Matt
