FOZ500
posted on 7/6/08 at 07:02 AM |
sick zetec
Hi there I am looking for some answer to which way to turn I’ve just finish my cross flow to Zetec build all going well. Zetec in/ Motorbike carbs
fitted/Megajolt fitted/ starts on the button first time. Goes like stink.
I took it to my local rolling road and he started it set the carbs up only then did we notice
smoke coming from the exhaust.
We then found out that cylinder 3 and 1 were getting oil in
Like most engine I got it from a friend. Did not see it running. Told it was a good one and to be honest I believe him.
So what have I done. I got the head skimmed and I did crank it over on the starter with no oil in the engine some times.
So can it be the oil ring scrapers burnt out or can it be the head not mating with the block?
Then do I just say sod it and find a new replacement engine or do I remove the pistons fit new oil scrapers and ring. And then put it all back
together only to find out it was the head.
Or do I/can I fit a black top in replacement to the silver top or is this new can of worms
snapper
posted on 7/6/08 at 07:58 AM |
have you checked the valve stem oil seals?
I eat to survive
I drink to forget
r1_pete
posted on 7/6/08 at 09:00 AM |
If it smokes at start up after being stood say overnight, then clears up, chances are its the valve seals, oil drains past them into the ports and
bores as the car is stood.
If its much the same all the time, suspect the oil rings.
What happens if you run downhill on overrun, then boot it? if you get clouds of blue smoke, that indicates oil rings most likely as oil mist is sucked
by the rings on overrun, but poor stem seals can also contribute
will121
posted on 7/6/08 at 11:27 AM |
how did you know oil was gettin into the bore, did you use a end ascope or something or just the plugs oily? have you compression checked it.
madteg
posted on 7/6/08 at 01:17 PM |
Think it is oil scraper rings strck in very common problem with engines that have been standing for a while, try redex down plug hole into cylinders
and leave for 24hrs. (BE READY FOR THE SMOKE ON START UP)
FOZ500
posted on 7/6/08 at 02:45 PM |
Thanks for all the fast replys:
Firstly
Mr Snapper I’ve changed the valve stems oil seals and checked they are seated properly so hopefully they are ok
Mr r1 Pete it was doing it all off the way up to the rolling road and to But in my hast I’ve just ripped the engine out so I did no checks on it.
I am swaying the ring way it can’t hurt to change them gives me something to do is it a good idea to hone at the same time?
Mr Will121 I took the plugs out and used a long screw driver as a dip stick
But I could see a pool of oil on the top of the piston
Mr Madteg be quite honest with you I do not know how long it was standing for.
So I will go for the rings and scrapers where is the best/cheapest place to buy a set?
