Author: Subject: Bike Carbs to air filter - How?
Sporty
posted on 13/6/08 at 02:28 PM Reply With Quote
As above really, have got the bike carbs mounted but obviously need an air filter on.
Do I need part of the airbox from the bike or can I just bolt a blank filter back onto the carb bodies.
Any help and of photo's appreciated.
Ian
omega0684
posted on 13/6/08 at 02:32 PM Reply With Quote
on my set of r1 carbs i got a piper cross filter with a blank back plate and then just cut holes out accordingly, now i have r1 throttle bodies i use an r1 box as a template as it has the air temp sensor built into it and then modded the old back plate to fit.
hope this helps
posted on 13/6/08 at 02:39 PM Reply With Quote
I used a chopped down ST airbox and made up a carbon fibre plenum to take it to a tubular type cone filter.
see
linky
richardh
posted on 13/6/08 at 02:41 PM Reply With Quote
mnr racing can do you a plate cutout and the filter for about 75 squids i think
u2u marc n if you want to know more or mnrltd.co.uk
big_wasa
posted on 13/6/08 at 02:47 PM Reply With Quote
Bogg brothers just used Pu on a set of R1's
Sporty
posted on 13/6/08 at 02:54 PM Reply With Quote
Photo looks like what I need to do. Thanks for the info.
Ian
DarrenW
posted on 13/6/08 at 03:00 PM Reply With Quote
I think it depends what carbs you have and what filter you want to fit. I used Kawasaki Keihins and used the original back plate with rubber trumpets. I then got a K&N challenger filter and grafted that on. I have some pics i could send you if you U2U me your email address.
cryoman1965
posted on 13/6/08 at 03:46 PM Reply With Quote
I used these pipercross foam socks. Got them from Burtonpower Rescued attachment Engine.jpg
posted on 13/6/08 at 04:04 PM Reply With Quote
I made my own, with the aid of the original carb connecting rubber bits...
...but I have a habit of doing things the hard way!
r1_pete
posted on 13/6/08 at 05:36 PM Reply With Quote
mines made from a race can, and a home cut backplate Rescued attachment 2airbox3.jpg
