stupott901
posted on 16/6/08 at 08:26 PM |
gear linkage
hi there
wheres the best place to get an gear linkage for an mk with an 893 blade engine?
also will the standard blade throttle cable and clutch cable work or do they need shortening?
thanks stu
eznfrank
posted on 16/6/08 at 08:41 PM |
The one from MK is "average" but with a bit of fettling can be made good. Have you thought about a control cable shift instead?
Pdlewis
posted on 16/6/08 at 08:49 PM |
does anyone know a ball park for MK paddles and tube to go over the column?
ReMan
posted on 16/6/08 at 09:09 PM |
Build your own cable shift?
You can do it, I did
stupott901
posted on 17/6/08 at 07:45 PM |
hi have you any pics of your cable gear shift ?
mkindy95
posted on 19/6/08 at 12:43 PM |
Is cable better than linkages for gear change?
What is everyones opinion of linkages vs cable for gear change.
Surelly linkages are more positive than cables, if cables are better where can i buy one, not got the time to make myself.
Jubal
posted on 19/6/08 at 01:15 PM |
I broke my cable change this week, the first time I actually used it properly. It wasn't fitted by me so I'd not really paid attention to
how it was installed and set up. Badly as it turned out.
To avoid problems like I had it appears that you need to install it between two brackets that don't flex at all. Ideally you should also limit
the travel at the lever/paddle. Too easy to pull it too far otherwise.
Anyway, I had a linkage with rods before and I'm going back to that. I'm certain I could make a cable work but I like how robust a linkage
is. YMMV.
