stupott901
| posted on 20/6/08 at 07:34 PM |
fireblade sprocket
hi there
ive been tryng to take the chain sprocket of my blade engine so i can put on my propshaft adaptor on but no succes what is the best way to do it?
cheers
ChrisGamlin
| posted on 20/6/08 at 07:43 PM |
An impact gun would be the ideal way if you have access to a compressor, if not you can hire battery operated ones from HSS hire etc for about £10 a
day.
ReMan
| posted on 20/6/08 at 11:21 PM |
Jam the sprocket against the engine with metal things, Use a 6 sidded socket and a 2ft breaker bar
eznfrank
| posted on 21/6/08 at 09:33 AM |
If you have no further use for the sprocket then you could use a piece of wood inbetween sprocket and block which the teeth can bite into and
shouldn't damage block. Then big bar, job done.
