Jackman
| posted on 29/6/08 at 05:49 PM |
First post/ ride height
Hi all
i am building a bookish locost and was woundering what is a good chassis to ground clearence for our very bumpy british roads?
adithorp
| posted on 29/6/08 at 05:51 PM |
Less than the width of your avatar!
adrian
Welcome!
You might want to reduce the size of that avatar It takes up half the screen!!!
The sump to ground clearance is the most important measurement. Usually the sump is the lowest bit of the car rather than the chassis.
Most people run about 100mm sump to ground clearance from my recollection of previous similar threads..... You can run less but it starts getting a
bit scary going over speed bumps....
locoR1
| posted on 29/6/08 at 05:56 PM |
Welcome!
I've never seen one so big !!!!!!!!
Check out my CB500T Cafe Racer build diary
philw
| posted on 29/6/08 at 06:00 PM |
Typical American car, bigger than everybody elses.
Jackman
posted on 29/6/08 at 06:34 PM |
Sorry about that ! It was a tad on the large side. I will have to find another one thanks for the info BenB
DavidM
| posted on 29/6/08 at 06:39 PM |
I run my car 6.25" rear and 5.5" front, I got these figures from a Westfield build manual. My sump is 1.75" below the bottom of the
chassis rails. In nearly 4000 miles I've not had any problems with ground clearance, even over speedbumps.
I might lower the car a bout .25" in the near future, just to tempt fate.
Proportion is Everything
mark chandler
| posted on 29/6/08 at 10:12 PM |
Bottom of mine is completely flat, 4" front, 4,5" rear only dragged a few times.
Best way to set up is cut a couple of blocks of wood the height you want and shove them under the rails, tape measure is hard work !
alistairolsen
| posted on 30/6/08 at 06:49 AM |
provided your sump doesnt stick down more than the average, what rake does everyone run, and what front ride height beneath the chassis rails? The
front suspension geometry must have been concieved with a certain height in mind?
