mad-butcher
| posted on 12/7/08 at 07:22 PM |
Yamaha R1 Gearbox issues
Keep reading about these. but what exactly are the issues with the R1 gearbox
many thanks
Tony
fesycresy
| posted on 12/7/08 at 07:33 PM |
Only heard of a couple of people with problems and I bet these are high mileage donor engines.
I would say the R1 has taken over the 'blade as the most popular engine. The more engines in use, the more issues you'll hear of, just
because of the statistics.
fesycresy
r1_pete
| posted on 12/7/08 at 08:14 PM |
It was a problem on early R1's, the change dogs wear and cause it to jump out of gear. Not epedemic proportions, and no particular pattern,
I've heard and seen it on high and low milers, my 2001 gets ridden like I stole it every time I take it out and my box is fine... touch wood.
garage19
| posted on 12/7/08 at 09:19 PM |
My 99 road bike does this. It jumps out of second due to worn engagement dogs. Just stripped the engine out of it ths avo to rplace them. £250 in
genuine Yam parts if you nclude gaskets!
yorkshire-engines
| posted on 12/7/08 at 09:48 PM |
the above is true later 5JJ models were a lot better and the newer 5VY and 4C8 are spot on
iv only replaced these on grasstrack engines and they get a lot more abuse than bec owners will ever give there engine
cheer s malc
progers
| posted on 13/7/08 at 09:06 AM |
I must concur with Malc. 5JJ engines onwards have good strong gearboxes, certainly much more reliable and longer lasting than blade ones. Of course
there will be failures, you can't account for how an engine has been treated over its lifetime.
I have raced an '03 R1 for 3 seasons now with no failures, although I did replace the gearbox as part of a general re-build after the first
season as it was showing signs of wear (it was a 2nd hand engine with 6k on the clocks when I first got it).
- Paul
Koss
| posted on 16/7/08 at 12:47 PM |
If replacing gears it may be a good idea to have the dogs undercut.
