DavidW
posted on 16/7/08 at 08:54 PM |
Painting a Roll Cage
I've just welded the roll cage to my Indy and want to paint it black to match the chassis.
Any ideas what the best paint or technique would be?
Thinners to clean then spray hammerite was the obvious answer but doesn't seem popular?
Thanks!
blakep82
posted on 16/7/08 at 09:02 PM |
i don't see the problem with that myself.
I'm wanting to spray my chassis... think there's going to be more wated paint that actually hits the chassis though. i did hear somewhere
of putting a negative DC charge on the chassis and it'll attract the paint. we'll see...
are you thinking of brush painting (always looks crap with hammerite i think, loads of brush marks)
or spraying?
________________________
iank
posted on 16/7/08 at 09:10 PM |
Wouldn't use hammerite (unless the current powdercoat is hammer finish) as it tends to chip. If you insist then thinning with petrol is
supposed to give a better finish.
http://www.locostbuilders.co.uk/viewthread.php?tid=81042
What about talking to a local power coating company to see if they can do patch repairs.
Anonymous
DavidW
posted on 16/7/08 at 09:14 PM |
The cage is bare metal and the chassis black satin finish powder coat.
I was thinking smooth hammerite sprayed.
Can powdercoating be done in situ?
dhutch
posted on 16/7/08 at 10:29 PM |
Nothing wrong with painting it, but i have to say hammerite wouldnt be my first choice, altough i dont know what would.
colt_mivec
posted on 16/7/08 at 10:45 PM |
If the chassis is powder coated why not powder coat the rollcage aswell
Its cheap enough to get done and will look much better in my opinion
UncleFista
posted on 16/7/08 at 10:56 PM |
I like the look of the Hammerite Metalmaster , I've no idea whether it works
or not, but it looks good
Tony Bond / UncleFista
neilj37
posted on 17/7/08 at 06:55 AM |
The obvious choice for me would be "Chassis Black".
I used it on my TR6 chassis when i restored it and never had any problems.
Linky
You can get satin and gloss finish. Spray on or roller/brush
[Edited on 17/7/08 by neilj37]
a4gom
posted on 17/7/08 at 09:04 AM |
por15, google it, you get if from frosts
Perfect planning prevents pi$$ poor performance!
matt_gsxr
posted on 17/7/08 at 09:55 AM |
I'm with Neil,
Get the Frosts catalogue. Loads of good quality finishes.
Hammerite isn't the best (IMO).
Por-15 is a system, and some of them are UV sensitive. I think the product you want is probably:
chassis_black_P500
but you need to read the instructions as it isn't as simple as "normal" paint.
Matt
posted on 17/7/08 at 11:09 AM |
I used the POR-15 metal-prep stuff to start with, followed by POR-15 paint. Finally this was rubbed down to knock the gloss off, and black paint
sprayed on top. Far simpler to do than it sounds.
Lasted 3 years so far...
RK
posted on 17/7/08 at 04:00 PM |
My plan, half done up to now, is to brush thinned enamel on (done), and spray it on later for a smooth finish. How much abuse is it going to take?
It's not like people will be scratching it regularly, is it?
Simon
posted on 20/7/08 at 12:33 AM |
I did what RK has just suggested.
But I used Hammerite. Brushed on a light coat of Hammerite Smooth Black but with good coverage, then waited till it got a bit tacky and sprayed it
with Hammerite Smooth Black.
It was commented on that it looked powder coated. It has chipped a bit, but then I've been chucking lumps of steel over it, with my new
"cage". When it's all welded together, it'll get the same treatment.
Simon
MakeEverything
posted on 5/8/08 at 03:44 AM |
Yes you can get powder coating done in situ, but it has to be baked on in an oven, so youd have to strip to a bare chassis or at least non-heat
sensitive stuff only. I think youll be happier with a powdercoat finish, as itll match what you already have on the chassis.
Hammerite spray is ok, but messy, particularly if trying not to get it on anything else.... You will ALWAYS get some kind of overspray unless its
fully sheeted and masked, which none of us ever do, unless we own a proper booth.
Kindest Regards,
Richard.
Mark Allanson
posted on 5/8/08 at 08:14 PM |
Chassis black with a gloss roller, no brush marks, shinier than a shiney thing, safe cheap, easy to repair if you scratch it, paint made for the job -
the secret is in the name
