Author: Subject: Wheel Nuts
greggors84
posted on 16/12/03 at 12:53 PM Reply With Quote
Wheel Nuts
Just a quick Q for a mate, is it ok to use the nuts used on the standard steels, on alloys. Not sure what the nuts are like, he was a bit vague.
Chris
The Magnificent 7!
GO
posted on 16/12/03 at 01:27 PM Reply With Quote
I'd say generally not - alloy nuts should be made of the same stuff as the wheel.
Could be wrong though. I'd get the right ones if poss.
posted on 16/12/03 at 01:32 PM Reply With Quote
Alloy wheels MAY have a different-shaped recess than steel wheels - you will have to check the wheels. Also, nuts for alloys often have a sleeve in which the threaded bit turns (e.g. Ford Ghia nuts).
[Edited on 16/12/03 by David Jenkins]
SeaBass
posted on 16/12/03 at 01:36 PM Reply With Quote
Grayston Engineering seem to supply most aftermarket nuts and also spacers. I got mine locally after enquiring about suppliers... Also lots of variations I need open nuts...
Ben_Copeland
posted on 16/12/03 at 03:33 PM Reply With Quote
If it's ford... then no. Vauxhall yes, thats as far i as can say lol
BUT can also depend on the Alloys too
Ben
Locost Map on Google Maps
Enter Your Details Here
RoadkillUK
posted on 16/12/03 at 07:44 PM Reply With Quote
I have the old Capri Lasers on my car/chassis. I found that the original wheel nuts from the steel wheels just went through the holes on the Alloys.
There's a pic of some shiney alloy nuts in my photo archive.
HTH
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
DaveFJ
posted on 17/12/03 at 09:27 AM Reply With Quote
Allloy nuts - hmmm they'd be nice and strong then !
Dave
GO
posted on 17/12/03 at 10:17 AM Reply With Quote
I'm sure on the various alloys I've had in the past they've all had non-steel nuts anyway, just beefier than your average steel wheel nut. Could be imagining it mind you.
Fast Westie
posted on 17/12/03 at 10:29 AM Reply With Quote
Triumph Stags used alloy wheel nuts as standard
The car in front is a Westfield
Mark Allanson
posted on 17/12/03 at 08:47 PM Reply With Quote
Porsche 924's use alloy nuts - they need replacing about every third removal!
Sierra Ghia wheel nuts are about the cheapest you can get, just the petrol to the scrappy and deep overall pockets
geoff shep
posted on 18/12/03 at 07:54 PM Reply With Quote
Generally not, as the hard nut will mash up the alloy of the wheel. I just replaced steel with alloy and got a set of ghia wheel nuts - they're the ones with the sleeve like washer. With or without the sleeve, the mating end of the nut needs to be the same angle as the hole in the wheel.
These are the sort of things I got:
http://www.raldes.co.uk/2003/page060.htm
