posted on 23/7/08 at 04:46 PM |
What a day
I was due to change the oil in my daughter's Corsa so we gathered all the stuff and tools together. I put it up the ramps and drained the oil,
put the sump plug with a new copper washer and new filter on and filled it back up then went under to watch the oil peeing back out through a pinhole
in the sump . We ended up removing the sump which someone had had off before and had glued it back very firmly, had to chisel it off all the way
round and found three more holes rusted through. I welded them back up and refitted it and it doesn't leak now. It's all back together and
might not use the amount of oil it was getting through.
How the devil does a sump full of oil go rusty?
theconrodkid
posted on 23/7/08 at 04:52 PM |
gravel rash on the front,same on fiats and frauds
who cares who wins
pass the pork pies
posted on 23/7/08 at 04:57 PM |
It's got a quarter inch coat of Zinc 182 and some black back on it now, I hope it lasts the rest of its' days
johnston
posted on 23/7/08 at 05:36 PM |
I had same problem with one of my ma's cars
Just before mot she brought into my work to get it power washed lifted it with a fork truck washed it only to discover it was the crud on the sump
holding the oil in
its amazin what exhaust putty can do 15 mins before mot
Ben_Copeland
posted on 23/7/08 at 06:01 PM |
Lifted it with a fork lift???
Sure you didn't put forks through the sump
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
andylancaster3000
posted on 23/7/08 at 06:28 PM |
Had the same on mine. Ended up draining the oil, brazing the hole in situ and putting the oil back in as it was 8.30 on a sunday evening and I needed
it the next morning. Been like that for the last two years and without further problems!
They are in direct salt spray and probably get bombarded with sh1t so not overly suprising. IMO if you have a pressed sump I think it's best
that the sump gasket doesn't entirely do what it's meant to do!
Davros
posted on 23/7/08 at 07:44 PM |
Our Kid had a Fiat Punto that the oil filter rusted through!
carpmart
posted on 23/7/08 at 09:00 PM |
Should have changed the bloody thing a bit more often then!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
worX
posted on 24/7/08 at 05:05 AM |
The Oil Filter on the missus' Rover diesel rusted through!!!
How on earth does that happen? I mean I know it's in a stupid place, but the oil filter???
tim windmill
posted on 24/7/08 at 09:20 AM |
we had the same problem on a fiesta that we owned from new, 4 years old and the sump corroded.
