Author: Subject: rodend range of motion
ceebmoj
posted on 4/8/08 at 08:19 PM Reply With Quote
hi all,
I have been looking for a dater sheet to show the range of articulation of rod ends does any body have and data?
blake
nastamenov
posted on 4/8/08 at 08:30 PM Reply With Quote
You could try www.aurorabearing.com or www.nmb-minebea.co.uk and go to their catalogue pages.
Regards, Nik
ceebmoj
posted on 4/8/08 at 08:37 PM Reply With Quote
thanks
tadltd
posted on 5/8/08 at 06:19 PM Reply With Quote
Hi Blake,
Try this lot: ASKUBAL
This is the supplier for the LMP's rod ends and bearings.
Best Regards,
Steve.
www.turnerautosport.com
Kaspa
posted on 6/8/08 at 08:28 AM Reply With Quote
Blake, most quality rod ends have between 10 to 15 deg misalignment, it varies depending on size,the bigger the rod end the more angle it will cope with. but for extreem misalignment you can get specials that will cope with up to 65 deg.
hope that helps
cheers Kaspa
understeer= when you hit the wall front first
oversteer=when you hit the wall back first
HP= how fast you hit the wall
Torque= how far the wall moves when you hit it
ceebmoj
posted on 7/8/08 at 07:32 AM Reply With Quote
hi all,
i'm not relay sure what all the figures in the link below mean i.e. I was looking at the cm-m16 as it has the largest miss aligneemnt angle however witch number do you ues a1, a3, or a4?
http://aurora.thomasnet.com/viewitems/all-products-commercial-male-rod-ends-metric-units/eries-male-rod-ends-metric-general-purpose-economy?&forwa rd=1
I suspect that im looking for a a non standard item as I want somthing that can cope with maby as much as 60 deg
im looking for a joint that has however
Kaspa
posted on 7/8/08 at 08:02 AM Reply With Quote
Blake, try QA1, part No, PCYMR8T 1/2 inch 65 deg Misalignment, best i can help with.
cheers Kaspa
ceebmoj
posted on 7/8/08 at 09:24 AM Reply With Quote
hi there,
from witch suppler?
blake
nastamenov
posted on 9/8/08 at 11:17 PM Reply With Quote
I am not sure what a1, a3 and a4 mean either and I think the best is to download the drawing of the rodend you are looking for from their CAD Drawings page and find out the real misalignment angle for yourself
rpmagazine
posted on 10/8/08 at 02:47 AM Reply With Quote
have a look here:
http://www.pegasusautoracing.com/advcat.asp?CategoryID=SUSPENSION
www.racemagazine.com.au
