Author: Subject: Sump baffle plate thickness?
matt.c
posted on 9/8/08 at 11:13 AM Reply With Quote
1. Going to make a alloy zx9 baffle plate but how thick should it be?
2. Where can i get a piece of alloy sheet the thickness above measuring 12 inches by 12 inches? Ie places like B&Q ect?
3. I need to shortern my pickup. Do you just cut an inch out of the stem and just stick it back together edge to edge or do i have to sleave it in?
Many thanks locosters
worX
posted on 9/8/08 at 11:26 AM Reply With Quote
I think you are probably best making it in Stainless Steel...
I think the Ali ones can fracture.
matt.c
posted on 9/8/08 at 11:35 AM Reply With Quote
ok steve, what about the other questions?
mistergrumpy
posted on 9/8/08 at 11:44 AM Reply With Quote
I've used 1mm ally. (I think it may be 0.9mm to be honest) but I haven't shortened the sump, gonna try and get away with it. IRC from searching other threads yes you just cut as shown and some people have used a collar to help stick the pick up back together.
ChrisGamlin
posted on 12/8/08 at 07:19 PM Reply With Quote
Hi Matt
As just mentioned in my u2u reply, this is roughly how my uncle used to do them
ZX9 Pickup chop
ZX9 Pickup chop
Basically he'd cut the pickup off where it goes from tube to cone, then chopped again further up to get the desired length. He then machined a shoulder on the tube segment and reamed out the conical bit slightly until the tube segment would just about slide/snap into the conical section. He then glued them together with superglue I think, or possibly Epoxy resin (Araldite).
As to the thickness of the baffle plate, this is what happened to my original fireblade baffle:
Blade Baffle fatigue cracked
Im not sure what thickness it was but its the one Westfield / STM / Kit Car Workshop used to supply, I think it was about 1.5mm thick. With that in mind I'd go as thick as you can get away with, or preferably as others have mentioned use thin stainless steel if poss.
cheers
Chris
matt.c
posted on 12/8/08 at 07:42 PM Reply With Quote
cheers
Chris
How thin in stainless are you talking about then?
ChrisGamlin
posted on 12/8/08 at 08:44 PM Reply With Quote
Steel doesn't suffer from fatigue cracking like aluminmum so it only needs to be thick enough to support its own weight really, so 1mm or so at a guess
matt.c
posted on 12/8/08 at 09:18 PM Reply With Quote
Thank you chris
simoto
posted on 13/8/08 at 08:05 AM Reply With Quote
Oh dear thats another piece of rubbish i have bought in my ignorance(baffle as above)
Just cleaned the gasket faces last night.
Thanks for tthe heads up, had an idea due to other posts but not seen one photographed like that!
Being honest i was going to risk it, not now though. Cheers for that
How long was it installed?
striker/blade now complete, thanks to all on this site.
ChrisGamlin
posted on 13/8/08 at 06:31 PM Reply With Quote
The above was installed for about 3 years, around 20 trackdays and maybe 4-5k road miles, and to be fair Ive not seen another one go quite like that so its possible that one was a bad batch of metal. If I was fitting another though I'd certainly drop the sump on each oil change to check it was still intact, but probably would look to get a stronger one to avoid the worry.
