Poll: Nylock nuts -re-using [View Results]
I never re-use and throw nylocks in the bin as soon as I take them off
I will use them again if they are new looking or I have put them on and taken them off myself
I re-use them as long as they feel like the nylon is still stiff
I re-use if I haven't got the right size to hand new
I don't worry and re-use them unless they are obviously knackered
Author: Subject: Nylock nuts -re-using
caber
posted on 16/8/08 at 06:21 PM Reply With Quote
So we all know Nylock nuts are only supposed to be used once. I am just interested in how many of us actually follow this practice
Humbug
posted on 16/8/08 at 06:23 PM Reply With Quote
Option 6: I will reuse them if a) they don't look too knackered and b) it's not in a critical place (e.g. suspension!)
SeaBass
posted on 16/8/08 at 06:26 PM Reply With Quote
I tend to build things up using plain nuts, then once in final assembly I'll add the Nyloc. I'm a bit OCD with nuts and bolts I remove from older things - they tend to go in the round file on the floor. I do have box I've got "last resort reuse only" if they are unusual threads.
posted on 16/8/08 at 06:27 PM Reply With Quote
Option 6 for me too
designer
posted on 16/8/08 at 06:30 PM Reply With Quote
If it can't be turned by hand; re-use it.
worX
posted on 16/8/08 at 06:40 PM Reply With Quote
Option 1.
Buy a small pack of various size nuts/bolts at the start of the build or upcoming project and you will never have the need to re-use them.
Also this way the replacement ends up costing just a couple of pence...
I get my stuff from http://rivetwise.co.uk they are great blokes there and send stuff straight away...
tcr
posted on 16/8/08 at 06:44 PM Reply With Quote
option 5 then option 1 after wot ever the bolt was used for has fell off
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
thunderace
posted on 16/8/08 at 09:35 PM Reply With Quote
if you cant turn them off and on with your hand there good.
Canada EH!
posted on 17/8/08 at 12:02 AM Reply With Quote
Nylock nuts-re-using
I spend a lot of time around aircraft, which is were this product came from, from my experience the only ones who chuck the nuts after one use are military and passenger jets, most of ours go back on the aircraft after the annual inspection. 180 mph turbo charged single.
RK
posted on 17/8/08 at 01:04 AM Reply With Quote
And that is why I stopped flying airplanes for a living: you are flying whatever the boss has given you!!
That said, I have done up and undone every nut on the car several times.
Fozzie
posted on 17/8/08 at 02:08 AM Reply With Quote
Option 1 ........
Fozzie
johnston
posted on 17/8/08 at 07:12 AM Reply With Quote
Were nyloc nuts not designed to be re used several times?
I think it depends on the quality i.e. Type of nut your boss buys and needs to keep costs down throw it over your shoulder once off, type of nut we buy for own use prob better quality therefore use a couple o times.
If in doubt and nothin else bit of loctite does the job.
posted on 17/8/08 at 08:19 AM Reply With Quote
The USA car engineering guru Carroll Smith discusses this in one of his books - he re-uses his nylocks a few times, even on his competition cars, as long as they appear to be in good condition.
smart51
posted on 17/8/08 at 08:42 AM Reply With Quote
I reuse them if I have to. If I don't have one the right size. I don't reuse them on safety critical parts or if they look knackered. I've never had one fall off or even come loose.
wilkingj
posted on 17/8/08 at 08:54 AM Reply With Quote
Option One every time.
Are you REALLY REALLY sure you want to put your life (or some other innocent persons) at stake for the price of a 10 pence nut?
If it warrants a Nyloc (or a castelated and pinned Nut, then its there for a reason, and usually its safety.
PLEASE DONT DO IT.
The cost saving factor compared to the safety factor is just not worth it.
Best Regards
Geoff
http://www.v8viento.co.uk
owelly
posted on 17/8/08 at 12:30 PM Reply With Quote
I reuse. Unless I happen to have a new one in my hand which never happens!! Sometimes give the top of the nut a bit of a squish in the vice to crush the nylon bit if I think it needs it. I've never had anything come loose or fall off. Not of the car, bike or boat anyway!!
It's nothing to do with being a tightfisted Yorkshireman. I'm just been green and reducing my carbon footprint so I don't feel guilty when I drive a car that spews out filthy gasses and poisons badgers.
http://www.ppcmag.co.uk
djmnr
posted on 17/8/08 at 07:12 PM Reply With Quote
option 5 for me.. never had problems... yet
