Author: Subject: Paddle Shift, It only Bloody works!
charlierevell
posted on 28/8/08 at 11:01 PM Reply With Quote
Well I've spent a day and a half in the garage, and have a nicely polished, completely custom paddleshift!
Even did me a bit of welding which i havent done since leaving uni 2 years ago!
Il get some photos up tomo.
Just seems to need a little fiddle to get it right on the trickshifter side of things, at least it now doesnt work unless you pull hard enough rather than making a fluffed change like it used to!
Could possibly benefit thru changing on bell crank around but other than that im a happy man!
Tomorrows jobs are move the ignition and find out what stopped the speedo working!
Tango orange is an 'IN' colour!!
worX
posted on 28/8/08 at 11:14 PM Reply With Quote
Quality news!
Well done Charlie!
charlierevell
posted on 29/8/08 at 08:09 AM Reply With Quote
Cheers mate, hope yesterday went well!
Paul TigerB6
posted on 29/8/08 at 10:33 AM Reply With Quote
Yesterday was his last day as a free man!! Poor bugger will be married for 1hr now - thats if he didnt run away anyway!!!
So where's the pics of this paddle shift then?? Do you have full details of all the kit you used??
MK chippy
posted on 29/8/08 at 11:41 PM Reply With Quote
Any pics of this padel shift?
MK chippy
posted on 29/8/08 at 11:42 PM Reply With Quote
MK chippy
posted on 30/8/08 at 09:18 AM Reply With Quote
What's a piddle shaft?
Sorry, I must wear the glasses more often.
charlierevell
posted on 1/9/08 at 03:56 PM Reply With Quote
Right... Photos as i said!
First Cut
First Cut
Cut 2
Cut 2
Polished
Polished
polished 2
polished 2
Paddle assembly
Paddle assembly
Fitted
Fitted
Fitted Front view
Fitted Front view
Rocker set up
Rocker set up
Rocker close
Rocker close
Spigot Extension
Spigot Extension
Hope that helps those who wanted them!
charlierevell
posted on 2/9/08 at 07:41 PM Reply With Quote
3 posts for photos and now no comments....????
sucksqueezebangblow
posted on 3/9/08 at 08:03 AM Reply With Quote
Fantastic job mate! Really nice work! I got mine out for a trial fit yesterday. Looks like I will need to make new (bolt on) paddles as they are way too wide and foul the roll cage. Also need to come up with a modification to fit the sensor for the Flatshifter. I think I can just make out your sensor on the vertical shift rod. Any chance of a pic so I can take a closer look at how you fitted it?
charlierevell
posted on 3/9/08 at 09:15 AM Reply With Quote
I really want to get the paddle and mount water jet cut to get it looking spot on, but those will do at the moment as it works!
(Thinking carbon mmmm!)
The flat shifter rod just mounts to the rocker and then threads onto an extension. Ill get a good photos of it for you later.... I find it odd that one end is M4 and the other M6 but it all works!
