Paul (Notts)
posted on 4/9/08 at 04:26 PM |
Air/Fuel meter advice
Getting a little tired of trying to guess the correct mixture settings on my carb so thinking about getting an Air/Fuel ratio meter.
What I am after is a set up that displays the ratio when I am driving and can also data log the readings.
With it being a V8, I either need a meter with two channels or the ability to switch from one sensor to another as I would require a reading from both
exhausts.
Alternately I could have a fitting in both exhausts and just switch the sensor over to the other side to check them both.
Anyone got any recommendations or advice on a good set up…
Looking to spend around £200-300 max
Paul
Ps – don’t tell the misses about the cost – when it arrives it was only £50…..
jollygreengiant
posted on 4/9/08 at 04:34 PM |
By specific ratio the adiabetic ratio should be 14.8:1. However if this is being read as a Llamda value then a perfect ratio is 1.
Does this make sense.
cossiebri
posted on 4/9/08 at 04:55 PM |
I've got one of these
>>>Linky
It can also display any of the sensors from my ecu,not fitted it yet just played about a bit ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
If it doesn't fit MODIFY it!!
Cheers BriF
posted on 4/9/08 at 06:29 PM |
I do like a nice bit of BLACKMAIL. can't help with the meter though.
Have a look at the post by Martin (Piddy ) in the fuel injection section .
[Edited on 4/9/08 by rusty nuts]
