Author: Subject: Build progress again - Hungarian MNR
Gergely
posted on 9/10/08 at 08:37 AM Reply With Quote
Hi, I just thought I'd show you a couple of pictures on where we are after 12 days spent on the car.
The engine is in place, cooling in place, Pipercross airbox fitted.
We are starting the engine-wiring this weekend and once the wiring is sorted we continue with the bodywork.
Any comments, tips appreciated!
Gergely
Mr Whippy
posted on 9/10/08 at 08:54 AM Reply With Quote
yeah they are, looks good too
Gergely
posted on 9/10/08 at 09:08 AM Reply With Quote
Pics not showing!
I added the pics to my Photo Archive, too just in case it doesn't work for some.
Gergely
graememk
posted on 9/10/08 at 09:49 AM Reply With Quote
looking like a very nice tidy build there chap...
why such a large starter motor ?
omega0684
posted on 9/10/08 at 09:52 AM Reply With Quote
where did you get that airbox from and how much was it?
Gergely
posted on 9/10/08 at 10:55 AM Reply With Quote
The airbox is from MNR and cost around 200 pounds from memory. Around the same as on the Pipercross webpage. It has a flexi hose that we will route underneath the radiator to suck nice fresh air... The question is how much dust/water it will suck with it... we have not decided on the ideal position yet.
TimC
posted on 9/10/08 at 11:44 AM Reply With Quote
Very nice! That is one nice looking radiator too!
Won't you have to take the exhaust, wishbones etc off to fit the tub?
omega0684
posted on 9/10/08 at 12:00 PM Reply With Quote
what about ducting the inlet into a bonnet bulge or nose cone vent?
Gergely
posted on 9/10/08 at 02:08 PM Reply With Quote
We will. Only one side is mounted up temporarily to be able to measure the holes for the wishbones, pushrod, etc. The same with the manifold... we need to measure where to cut the hole...
Yes, that is an option. I am not keen on a bonnet bulge and ducting the inlet pipe to the bodywork would be difficult without a NACA duct or bulge... we will see. At the moment we plan just to run it on cold air instead of the hot engine bay air.
erwe
posted on 9/10/08 at 02:18 PM Reply With Quote
We have bad experience with these airbox.
Not strong enough.
Triggerhappy
posted on 9/10/08 at 03:49 PM Reply With Quote
Not strong enough.
Not strong enough?
What happens with it....
andylancaster3000
posted on 9/10/08 at 05:43 PM Reply With Quote
It all gets a bit conjested on that side of the car with both the engine and driver controls there. The other side (the proper side ) must be pretty empty! Getting the chassis and corner weights balanced must be fun!
bassett
posted on 9/10/08 at 05:47 PM Reply With Quote
Looks like some good progress and how mine looked a week or two back before it all came off for the body which im hoping should be on over the weekend. Have you managed to get all your header pipes into the collector completly or just a few mm in?
Gergely
posted on 10/10/08 at 07:43 AM Reply With Quote
What was your bad experience with it? Can you elaborate please?
Well, there is not much we can do about that... we try to move everything we can to the other side, and MNR originally designed the car so that the engine is not central, but moved to the right as much as possible, so passenger footwell is also a lot narrower than the driver side. And the propshaft is at quite an angle... :-)
Only a few mm in so it all stays together and we can measure where the bodywork needs cutting. We probably won't be able to fit the manifold at once once the body is on, all pipes need to go on separately, so there is no point in hammering the collector on the pipes just yet...
Thanks for your comments!
Gergely
matt.c
posted on 10/10/08 at 09:11 PM Reply With Quote
looking good mate. Glad you have finally started playing with a real 7. (LFS)
Gergely
posted on 13/10/08 at 04:43 PM Reply With Quote
Thanks Matt!
True, don't get much time behind the computer wheel now... but hopefully will soon in the MNR!
And now the engine runs, too! See new thread!
