New Topic New Reply
Author: Subject: Front bulkhead - do I need one?
Jesus-Ninja
posted on 15/10/08 at 12:31 PM Reply With Quote
My engine is mid mounted, so do I need a bulkhead to partion the cabin off from the rack, rad and fluids etc? Or do I just need to be able to show that the front of the cabin is protected from the outside?
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
donut
posted on 15/10/08 at 12:35 PM Reply With Quote
I would, just in case something falls off and embeds itself in your leg....or worse!!
Mr Whippy
posted on 15/10/08 at 12:37 PM Reply With Quote
ditto could be quite a laugh if you hit a puddle
Jesus-Ninja
posted on 15/10/08 at 12:51 PM Reply With Quote
Completely flat, sealed underside
Mr Whippy
posted on 15/10/08 at 12:57 PM Reply With Quote
Ha! famous last words, thought the rack was visible, so how can it be sealed then...?
this will be you -
[Edited on 15/10/08 by Mr Whippy]
Howlor
posted on 15/10/08 at 12:58 PM Reply With Quote
Brake fluid round your nads would be none too pleasent!
Jesus-Ninja
posted on 15/10/08 at 01:06 PM Reply With Quote
Ha! LOL!
Tie rods will pass through rubber seals...?
OK then, to quote "Life of Brian" - 'E's making it up as he goes along... Good point though
this will be you -
posted on 15/10/08 at 01:08 PM Reply With Quote
Do you not need a firewall
pewe
posted on 15/10/08 at 01:18 PM Reply With Quote
Nick, agreed but the Yanks don't call it a firewall for nothing. Having seen the damage fire can do to flesh and bones (mate who crashed & burnt at le Mans) I'd be thinking about self-preservation rather than regulations.
Cheers, Pewe
Jesus-Ninja
posted on 15/10/08 at 01:19 PM Reply With Quote
Well, that's my question... There's the body work at the front, and then a void with a rack and Brake / clutch cylinders in, then me.
Mr Whippy
posted on 15/10/08 at 01:34 PM Reply With Quote
no you don't need it for the SVA, but realistically it will be drafty, wet and rather unpleasant, unless you are sealing up the inner arches (or whatever you have on the car) with rubber boots over the trackrods?
Jesus-Ninja
posted on 15/10/08 at 01:59 PM Reply With Quote
OK, that's good to know. To be honest, it was more of a hypothetical question. There will be protection of course, but wasn't sure whether the driver had to be sealed off from the rack, master cylinders and so on. It's simply easier to moce the bulkhead in front of these.
[Edited on 15/10/08 by Jesus-Ninja]
adithorp
posted on 15/10/08 at 02:02 PM Reply With Quote
A bit warm with the air from the rad'. Risk of scolding should a coolant hose or the rad burst. Very difficult to seal the track rods as they pass through the innerwings due to thier range of movement.
http://jpsc.org.uk/forum/
wilkingj
posted on 15/10/08 at 02:30 PM Reply With Quote
How about using some old car inner tube to make a flexible gaiter to seal the steering rack to the bulkhead.
I mean it doesnt have to be indestructible. Just enough to give you some minor protection from spilled liquids (even battery acid?) etc.
I would not have it open into the cab area. in the event of an accident it may not be the fluids from your car that get you.
Hmmm could even save you from a wasp getting blown up your trouser leg or simmilar!.
Just my 2 reils worth.
Best Regards
Geoff
http://www.v8viento.co.uk
Ninehigh
posted on 16/10/08 at 11:26 AM Reply With Quote
Lol I can imagine that at the pearly gates!
"Well I never sealed off the bulkhead, and a wasp flew up my trouser leg at 80mph..."
New Topic New Reply
