Author: Subject: Temp sencor connections
sonic
posted on 16/10/08 at 09:43 PM Reply With Quote
Hi all
I have a water temp sencor which has two spade type connections
Is one Live and the other an Earth which just wants earthing to the chassis?
If so does it matter which one you Earth
graememk
posted on 16/10/08 at 09:46 PM Reply With Quote
i've taken all my earths back to one point
matt_claydon
posted on 17/10/08 at 07:36 AM Reply With Quote
Yes, one is ground the other is signal. If it's for a gauge just ground it anywhere but if it's a sensor for an ECU then ideally you should take the earth back to the ECU as well as the signal. It doesn't matter which way round you wire them, the sensor is a simple resistor.
sonic
posted on 17/10/08 at 08:19 AM Reply With Quote
Thanks guy's that great
bracey
posted on 21/10/08 at 06:38 PM Reply With Quote
sorry to hijack post but is the same said for the sender on a c20 xe ?the blue plug
ie one to gaege the other to ground?
cheers
richard
