swanny
posted on 18/12/12 at 10:39 AM |
Outdoor/garage lights
Hello all,
i'm after a way of turning on my garage lights from the kitchen (about forty feet) before i go outside. (so i can see where i'm going in
the garden)
I dont want a PIR as we have lots of cats etc around and dont particularly want to run a cabled switch all the way down the lawn.
i've seen some remote control plugs at maplins here
which i thought i could stick in the garage window facing the house to activate a light (either internal or external)
would this work? any better ideas?
cheers
paul
designer
posted on 18/12/12 at 11:12 AM |
You could mount a PIR, angled upwards so passing cats, won't turn it on.
gremlin1234
posted on 18/12/12 at 11:20 AM |
the maplin remote switch should work, but you might want a remote control in the garage as well as the house.
chris-g
posted on 18/12/12 at 11:23 AM |
I bought a very similar set to those from Asda in West Bridgford a couple years ago, they were only £5. Worth a try if they are still doing them at
that sort of money.
swanny
posted on 18/12/12 at 11:55 AM |
asda westbridgford is 5 mins from my house!
where in notts are you?
enjoyed your re build thread BTW
paul
chris-g
posted on 18/12/12 at 12:02 PM |
Thanks Paul. I am in Ruddington so not far from Bridgford either. Always happy to have a natter with fellow local petrol heads.
Slimy38
posted on 18/12/12 at 01:03 PM |
We have a set of the remote controlled plugs for our christmas decorations, as the plugs are behind the tree. It's so much easier to push a
button on the remote than have to reach behind the tree!
I'm not sure they've got a 40 feet range though, I've never tried more than about half that.
rallyingden
posted on 18/12/12 at 04:44 PM |
Remotes wont have the range.
I ran a bit of phone wire between house and garage, hooked up a 12 v relay and 12v power supply in garage, switch is in house, brings relay in and
that switches lights on.
Oh and my burgular alarm also activates same relay so if alarm goes off Garage lights come on.
RD
[Edited on 18/12/12 by rallyingden]
CNHSS1
posted on 18/12/12 at 05:50 PM |
you can get swithing units that work off a text message, almost infinite range. Plug into 13amp socket and voila!
by Dad had one on his big static caravan, used to text the central heating 30mins before he arrived so it was toasty!
