Author: Subject: Quick-Release Boss + Horn
DapperRob
posted on 15/7/15 at 02:03 PM Reply With Quote
So I've just fitted one of these and it works a treat. Only question is how to adapt it so that the horn will fit?
http://www.carbuildersolutions.com/uk/quick-release-steering-wheel-boss-gold-anodised
ravingfool
posted on 15/7/15 at 02:48 PM Reply With Quote
Er, doesn't look like it will... How about a little button on your dash?
I picked up one of these second hand but unused recently (hence the colour):
nrg hub
and it comes with necessary attachments for routing your horn in (which I have done). If it doesn't have appropriate contacts built in you're going to either have to risk modifying what you have or accept a horn button elsewhere - on your stalks or dash mounted switchgear.
peter030371
posted on 15/7/15 at 02:56 PM Reply With Quote
If you want electrical connectors then you need a QR boss with a built in connector.
You may be able to find one that fits the boss you have and do it yourself. The sort of connector you need is a Lemo type (B series I suspect)....I have a pair here for my QR but mine came with them fitted so not sure what part numbers you need. I have had a quick look here and you may find that something like a EGG socket and a FAG plug is what you need but again you will need to check what size to suit your boss.
Lemo used to be difficult to get unless you had a trade account but I see loads on ebay now so not impossible
edit to add that this is the unit I have and you can sort of see in the picture how the connectors are fitted. http://go-race.co.uk/shop/4582749947/electrical-quick-release- steering-hub/9459124
[Edited on 15/7/15 by peter030371]
