Author: Subject: Sierra driveshaft= Granada?
8smokingbarrels
posted on 9/9/03 at 10:24 PM Reply With Quote
Does anyone know if Sierra driveshafts are the same as Granada's- also the rear caliber?
Thx
chris
stephen_gusterson
posted on 10/9/03 at 08:45 AM Reply With Quote
the rear calipers on the disk models 'look' the same - check a halfords brake catalog, if they spec the same pads thats an even bigger clue, or look in a scrappy to confirm.
AFAIK 'std' sierras run rear drums but later models had disks.....someone might correct that......however, it seems that all granada and all disk models ran lobro joints and shafts instear of the tripode ones of drum sierras. I donno if the length is the same, id bet on them not being so....
atb
steve
GO
posted on 10/9/03 at 09:20 AM Reply With Quote
I'm not sure it was proven but I think previously the conclusion was that the lobros were the same length on Sierra and Grannys. The reason being that the Grannys rear track is only an inch or so wider than Sierra so there should be more than enough "play" in the shafts to allow for half inch each side. And I'm sure Ford wouldn't manufacture a different parts unless they had to...
EDIT - just making my english make sense!!
[Edited on 10/9/2003 by GO]
stephen_gusterson
posted on 10/9/03 at 10:21 AM Reply With Quote
I agree, but an inch would take up nearly all the play in the joints i have......
atb
steve
ChrisW
posted on 10/9/03 at 07:10 PM Reply With Quote
The Granny shafts are a longer than Sierra ones but the play will usually make them suitable for a Sierra width car. They are also five stud and have bigger bearings on the outer ends so you can't swap the Sierra flanges on to get around it (I tried unsucessully!).
Also, most Grannys were fitted with the 7.5" diff whereas most Sierras used the 7". (note I say 'most' The shafts are not interchangable between diff types.
Some good news tho - yes, the calipers are the same and I believe there are brackets out there to allow them to be used on a drum rear end.
Chris
My gaff my rules
8smokingbarrels
posted on 18/9/03 at 09:03 PM Reply With Quote
Thx for the info guys- u've surpassed urselves!
Just one more question- can anyone tell me the diameter of the 'splined' part of the sierra or granada driveshaft. Had an idea of fitting one into a mondeo upright. The 'splined' part of it measures 28mm if thats any help
chris
stephen_gusterson
posted on 18/9/03 at 09:25 PM Reply With Quote
im gonna be taking my shaft of for mods at the weekend.
if i forget to measure it u2u me sunday
atb
steve
im certain to forget btw
8smokingbarrels
posted on 19/9/03 at 08:53 PM Reply With Quote
Will do Steve- thx
chris
cosworth
posted on 26/9/03 at 09:25 PM Reply With Quote
most sierras have a 4" od lobro most granadas have a 4.4 " lobro joint also sierras have M8 bolts granadas have M10 bolts
stephen_gusterson
posted on 26/9/03 at 10:36 PM Reply With Quote
the 87 granada I have look much more like m8 bolts - they have a T40 head.
atb
steve
