AL20vT
posted on 15/1/08 at 05:26 PM |
Couple of Pinto questions
Hi
Can someone identify these 3 points on the pinto engine, & what i do with them please.
AL
Pdlewis
posted on 15/1/08 at 05:29 PM |
Looking down
1. water temp
2. breather
3. oil temp
rayward
posted on 15/1/08 at 05:30 PM |
one in top pic is engine temp sender, connects to temp gauge,
left hand one in bottom pic is crank breather connects to car/inlet on standard engine,
right hand one in bottom pic is oil pressure switch, connects to oil warning light
hth
Ray
[Edited on 15/1/08 by rayward]
Paul TigerB6
posted on 15/1/08 at 05:37 PM |
^^^ 2 each i recon
1 Water temp sender
2 Oil breather
3 Oil Pressure switch
Paul TigerB6
quote: Originally posted by Paul TigerB6
^^^ 2 each i recon - pretty much 3 for Ray
1 Water temp sender
2 Oil breather
Paul TigerB6
posted on 15/1/08 at 05:38 PM |
1 Water temp sender
2 Oil breather
Must hit Edit rather than quote though!!
posted on 15/1/08 at 05:51 PM |
looks similar to crossflow.
no.3 would be oil pressure switch., others as ^^^.
mcerd1
posted on 15/1/08 at 08:31 PM |
quote: Originally posted by rayward
left hand one in bottom pic is crank breather connects to carb/inlet on standard engine
or into your catch tank...
loads of previous threads about this
DarrenW
posted on 16/1/08 at 09:57 AM |
There are loads of threads on pinto crank case breathers etc, but if you read my most recent thread bare in mind my breathing issues were due to rogue
dipstick of unknown origin and resultant overfilling of sump.
The oil pressure switch as standard on a pinto just lights the dash light of oil pressure drops. If you want to know actual pressure you can get a
dual low warning and pressure sender (ive fitted one from ETB). For oil temperature you need to fit a seperate sender somewhere. If modding the sump
then you should be able to fit a suitable boss, otherwise you can modify an oil gallery plug for the sender (what i have done).
Just as a summary to oil breather if you opt for catch tank - either modify the PCV (remove plunger and spring) or replace (burtons do shiny one,
otherwise cortina oil trap will work). Pipe to tank highish up in largest pipe you can manage (1/2" bore will work). If you have rocker cover
cap with outlet, pipe this to the tank also. Should work fine if oil level is ok. Tank does not need to be fancy £40 job. £2 ali drinks bottle will
work. If all is well it wont fill that fast that you need a sight glass.
