FlansS14
posted on 8/3/07 at 03:34 PM |
Where can i get a Turbo downpipe custom made
when fitting a one off turbocharged eongine into a westi where is the Best place for 1off Turbo exhaust systems, most places don't have t28
flanges to start with. also does anyone do a "large" box to suit 300+bhp with a 2.5"-3" id
Why didn't i just make it simple!
scoop
posted on 8/3/07 at 03:44 PM |
Sounds mental chap
Where are you 'cos there is a guy up my way ( Lowestoft, Suffolk ) who can and will make anything for you at a very reasonable price.
meany
posted on 8/3/07 at 03:49 PM |
http://dir.mycartel.co.uk/Autos/Exhaust_System_Mnfrs_&_Wholesalers/
have a look on there.
i have seen the work done by "Alunox" in Wrexham....quality...price?.
chrisg
posted on 8/3/07 at 03:51 PM |
I'd get in touch with Mk developments
Website
They are one off exhaust specailists and very keenly priced.
HTH
Chris![](/images//smilies/wink.gif)
dougal
posted on 8/3/07 at 04:17 PM |
Hi mate,
interesting stuff. im in the middle of fabricating a down pipe from a t28 into a 3" system. not sure about the silencers but jetex do a
3"one that could be up to the job but would need a 90 degree bend putting on.
Im running a vauxhall redtop with a T28 and adapted sr20det manifold. should be putting out in the region of 400bhp once im running a bigger tubby.
i was thinking of running an sr 20 but the vauxhall is not so tall and bits are alot cheaper, however i do run an s14 as my everyday car running about
300bhp.
in terms of the down pipe im buying some bends and cutting to length, machining up a flange then getting a local guy to tig it. suppose i could be
persuaded to make 2. where you based?
FlansS14
posted on 8/3/07 at 05:01 PM |
400Bhp... i thought i was mad
The trouble im having is the tight angle (see pic)
I Have arround 110mm from the flange to the footwell
http://s13.photobucket.com/albums/a282/FlansS14/?action=view¤t=28012007036.jpg
gonna be tight...
Simon
posted on 8/3/07 at 08:44 PM |
Do a rubbing of the flange and send it to someone like sciss (http://www.sciss.co.uk/) who will water jet cut it from your chosen material (10mm
stainless is what I used), then get in touch will milner offroad for a stainless bend or two (mentioned elsewhere on here), and make yourself an
exhaust
These are my (as yet unfinished) efforts:
3" into 2.5" done by slitting larger and bending in, then welding up.
Simon
[Edited on 8/3/07 by Simon]
Jed
posted on 8/3/07 at 09:05 PM |
Not sure where you are but there is Concept Engineering and Fabrication at Wymondham - Norfolk.
Ex Lotus chaps and they've done a couple of Westfields and they do custom make silencers to whatever size is required. Reasonably priced
too.
01953 601954.
FlansS14
posted on 9/3/07 at 10:56 AM |
Cool, thanks for the reply and the pics.
Im baised near milton keynes if there is someone closer. I remember seeing some T28 - 3" round adaptors. that would make things easyer.
daviep
posted on 9/3/07 at 02:58 PM |
THESE guys were the cheapest source oh stainless bends I could find, they also do 1 x
pipe dia. bends (very bottom of page) which would fit between your bulkhead no problem.
Regards Davie
[Edited on 9/3/07 by daviep]
FlansS14
posted on 9/3/07 at 03:44 PM |
Dave there's no link
NS Dev
posted on 9/3/07 at 04:02 PM |
SDW Light Fabrication in Banbury.
They make all the westfield race manifolds and anything non "off the shelf" that westi need. Very good prices too, they mandrel bent all
my stainless for my manifold.
daviep
posted on 9/3/07 at 04:23 PM |
Just seeing who was paying attention try THIS instead
Sorry
