mandbsheldon
posted on 23/1/06 at 07:02 PM |
Can any one help?
Would anybody know the year of manufacture for my Fazer engine, if I was to give you the engine number?
Need it for the SVA form.
Thanks,
Leigh.
Messenjah
posted on 23/1/06 at 07:26 PM |
i dunno if it will work but just try putting it into google
mandbsheldon
posted on 23/1/06 at 08:03 PM |
Good idear, tried and nothing.
jamestziros
posted on 23/1/06 at 08:10 PM |
Haynes Manual
Hi there
Not sure what a Fazer is but if it has a Haynes manual for the vehicle it may stipulate the year of the vheicle for a set Engine Number Range.
James
highspeeddirt
You should be able to find it in the relevant Haynes manual.
However, if it's not pre 1995 then I don't think it really matters as they will give it a full cat test anyway so you might as well make
it up. If you need to prove it is pre 95 then you will most likely need a letter from Yamaha.
mandbsheldon
posted on 23/1/06 at 08:16 PM |
Pritty sure it's not pre 95 and was expecting to use a cat, so what do you think? just guess the year. Will I not be any worse off?
Leigh.
highspeeddirt
posted on 24/1/06 at 06:12 AM |
At my last SVA the inspector said that if I couldn't prove they age of the engine it would be tested to the current levels. I would say they are
unlikely to ask for proof of age of a post 1995 engine so you may as well have an educated guess
badding
posted on 24/1/06 at 09:48 AM |
Just call Yamaha, and give them your engine number, they can look it up in their database and give you the framenumber and the year it was build.
I did it for my zx9r and recieved an official note from kawasaki stating the chassis number and when it was build, that should be fine for SVA
