Author: Subject: MEV ROCKET BEC?
stig mills
posted on 3/3/07 at 11:55 AM Reply With Quote
MEV ROCKET BEC?
Been asked a few times now about a BEC version. Dont wont to offer too many options or claim anything will fit like some have in the past. So what do you think I should go with in terms of engine/diff. I believe good value will be important to most. Your opinions would be greatly appreciated, kind regards Stig Mills
nitram38
posted on 3/3/07 at 11:59 AM Reply With Quote
Simple, R1 yamaha because they are relatively cheap injection 05 is 182bhp. They also only require a baffle instead of a dry sump.
Sierra lsd diff converted to chain sprocket:
diff2
diff2
I am in the process of building an atomesque car and I will be using this set up.
I am just looking for a garage to store my car while I start on the chassis. So far I have got 90% of the parts together (9K worth !!!)
[Edited on 3/3/2007 by nitram38]
ChrisGamlin
posted on 3/3/07 at 01:33 PM Reply With Quote
Im not so sure the 04-06 engines are particularly cheap though are they, last time I looked they seemed to be not far below £2k?
An earlier engine will still give you 150-160bhp though, and very well proven. The Blackbird engine could also be worthy of consideration for a cheap 160bhp seeing as it will be transversely mounted so shouldnt have the oil starvation problems that inline mounting them brings.
nitram38
posted on 3/3/07 at 01:37 PM Reply With Quote
R1 is not super cheap but I bought a complete 700 mile engine from yorkshire engines for £1875.
When you consider it is almost brand new, then it is not bad.
Why put cheap engines in a bec with high mileage and having been thrased to bits?
Although it is a lot cheaper than a busa when you consider a dry sump install. These setups cost £3-5000
ChrisGamlin
posted on 3/3/07 at 01:52 PM Reply With Quote
Yeh I agree its not really worth putting high mile smokers in to save a few hundred quid, but to put it into context a couple of years ago I bought a mint 03 engine that was just over a year old at the time with 3k miles on it for £1200, but engines of the same age/mileage seem to be nearer £2k now, admittedly with a bit more power.
nitram38
posted on 3/3/07 at 02:04 PM Reply With Quote
About another 30bhp to 182 for an injection.
I forgot to factor in the power commander plus cat though !
ChrisGamlin
posted on 3/3/07 at 02:21 PM Reply With Quote
Mine's also injection, and in reality the 04> engine has more like 15-20bhp over an older engine (and less power below 8k) because the figures quoted include ram air which isn't applicable for BEC use.
[Edited on 3/3/07 by ChrisGamlin]
nitram38
posted on 3/3/07 at 02:27 PM Reply With Quote
You can still get ram air on a rear engined car because the engine faces the "right" way and you can keep the standard airbox facing into the wind.
ChrisGamlin
posted on 3/3/07 at 02:31 PM Reply With Quote
Yes but you can't beat physics, its benefit is virtually non existent until you hit ~90-100mph, and does't give more than a couple of bhp until much higher speeds, speeds that are unattainable in a BEC.
