<<  1    2  >>
Author: Subject: Pre sva pics
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 12/7/07 at 10:53 AM Reply With Quote
Pre sva pics
just looking for general comments, sva is two weeks away so plenty of time to fix things!!
I understand that both the front and rear lights may be a problem but in both cases some people have passed others have failed so in the case of avoiding extra unnecessary expense they are staying as they are for the test.
all other comments welcome
Excuse the dirty wishbones!!
Avoneer
posted on 12/7/07 at 11:07 AM Reply With Quote
Headlights?
Apart from that it looks good.
What mirrors are those?
Thanks,
Pat...
rayward
posted on 12/7/07 at 11:09 AM Reply With Quote
very nice,
just a couple of points i spotted,
contactable edge on top of air filter
top harness mounts may be too low
front flexi brake hoses might need clipping back
hth
ray
[Edited on 12/7/07 by rayward]
Mark Allanson
posted on 12/7/07 at 11:10 AM Reply With Quote
Nut covers on the air filter nuts, and have you measured the radius of your instruments?
posted on 12/7/07 at 11:12 AM Reply With Quote
nuts on the air filter cover?
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
I believe they are ZR mirrors bought from mac#1 at newark this year.
Originally posted by Avoneer
Headlights?
Thanks,
Pat...
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/7/07 at 11:15 AM Reply With Quote
The flexi hoses don't contact anything so do i still need to clip the back?
Looks like i will need to have a look at the filter, not sure what to cover the nuts with. they are quite small, any ideas where i can get some small covers from?
Not much i can do about the seatbelt mounts, if thats a problem mk will have to sort that out!
cheers everyone
Originally posted by rayward
very nice,
hth
ray
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/7/07 at 11:16 AM Reply With Quote
The dials are fine not sure about the warning lights though - has anybod had any experience of these? They were bought from a show though i cant remeber who exactly from.
welderman
posted on 12/7/07 at 11:23 AM Reply With Quote
My only concern is, it's not raining there.
Car looks good in green.
Thank's, Joe
I don't stalk people
ditchlewis
posted on 12/7/07 at 11:25 AM Reply With Quote
have you restricted the steering rack to limit the lock. one i failed on and a common fault with the indy.
ditch
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/7/07 at 11:39 AM Reply With Quote
no, how do you that :S
ditch
Edit to say - how do i know if my rack is ok? the arches dont foul on anything and neither do the hoses?
[Edited on 12/7/07 by iscmatt]
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/7/07 at 11:40 AM Reply With Quote
haha, cheers
mookaloid
posted on 12/7/07 at 11:46 AM Reply With Quote
Looks a pretty good effort to me
DaveFJ
posted on 12/7/07 at 12:12 PM Reply With Quote
The harness top mounts could be an issue. have you maesured them in accordance with the SVA rules? Also IIRC the seat holes they pass through must be 'structural' as the belt is changing direction at that point. You may be asked to prove that the holes are structural - ie steel frame seat with bar across just be;low holes....
Or maybe it will be fine... what do i know I haven't finished building yet!
Looking good BTW, good luck!
Dave
Bladerunner
posted on 12/7/07 at 12:34 PM Reply With Quote
S.V.A
Watch the height of your seatbelts relative to the seats. Mine were to low and failed and I had to put extentions on the bolts to bring them up to the correct height. I also failed because I did not have any cushioning on the front wishbone arms. Good luck.
pajsh
posted on 12/7/07 at 12:47 PM Reply With Quote
Seatbelt mounts also.
Mine (book build) were mounted simlar to yours and with Cobra seats failed by around 10mm. Holes in Cobra seat are not regarded as structural as I thought (hoped). I had to weld in a cross brace and mounts to get the extra height.
Difficult to check without the right piece of kit but I would have thought MK should have this one covered .
I used to be apathetic but now I just don't care.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/7/07 at 12:51 PM Reply With Quote
i blomin hope so! does anyone have a diagram to show the dimesions, i cant find my sva manual atm!!!
ditchlewis
posted on 12/7/07 at 01:10 PM Reply With Quote
Mine also failed on seat belt mounting height. the common consencus was the mountings are set for fibre glass bucket seats with no padding. i've had to buy cussion seats from the tiger R6 to get the height. you need to be 503mm from the centre of the seat cusion to the upper mounting point. i had 420mm with the baby cub seat. can you get a letter off the seat manufacture that the seat can take the loads?
the steering on mine turned far enough for the track rods to touch the cycle wing stays, and also put pressure on the flexable hose as it enters the caliper.
solution is to restrict the rack by
springs 20mm inside diameter
or
alloy pipe over the rack (i'm using this one with a grub screw to prevent movement of the pipe)
or
a jubilee clip (sva mans informal suggestion)
all the above will be hidden behind the gator and out of sight.
ditch
ps the exaust clips (around the exaust) can be considered sharp, i angled them so the sva man had trouble toughing the bits that stick up with his measuring device.
[Edited on 12/7/07 by ditchlewis]
speedyxjs
posted on 12/7/07 at 01:40 PM Reply With Quote
Me like
Love the hubs
posted on 12/7/07 at 01:54 PM Reply With Quote
www.rootpeg.net/SVAMarch2004.pdf is available for when your manual is @ home
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/7/07 at 04:12 PM Reply With Quote
They really are truly awesome! haha
£14 i think, they were from motorworld if anyone wants a set, the next big thing? maybe not.
Originally posted by speedyxjs
Me like
Love the hubs
Marlon
posted on 12/7/07 at 04:17 PM Reply With Quote
Hi
Thats a nice looking motor, Only a couple of things that I can see,
1, Seatbelt height? Do you have runners on your seats? if you do, take them off and the mounting points are ok, with them on they are a fail for height,
2, What problem do you see with the rear lights? If they are a single led ring for side and brake lights they may try and pull you for this as you can't use the same fillament in 1 bulb to do 2 jobs, explain that they are led's and do not have a fillament and you should be ok. Mine passed with these on.
Thats all I can see.
hth. john.
edit to say....
you could use a blob of silicone on the nuts on the carbs, my motor was covered in the stuff for the test without a word said then just some white spirit to get it off after.
[Edited on 12/7/07 by Marlon]
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
richardR1
posted on 12/7/07 at 04:19 PM Reply With Quote
Regarding the seat height issue. I also have an Indy with Roadster 7 seats and SVA'd at Beverley where I presume you will be going. I have my drivers seat on cobra runners to allow adjustment and spaced the passenger seat so that they were sat at the same height. After measuring mine according to the SVA diagram I found I was just shy of the required measurement.
To try and get round this I made some spacers up out of steel tube and bought some longer high tensile bolts so I still had plenty of thread in the chassis tubes.
Went for SVA and got Paul (I think) who was spot on guy. He asked me about the spacers and understood why I had done them but said that he wanted me to remove them as he would prefer to have the bolts screwed right down to the tubes on the chassis so under less strain and he wasn't worried about the fact that I may be a few mm (12mm if I recall) low.
As I had already had a fail on the emissions which meant I needed a retest I decided to remove the spacers at home and get them ticked off at retest time. However when I went for retest I got different tester who looked like he had PMT and got the measuring apparatus out for the harness height test. Obviously it just failed. I explained what I had been told to do at my original test and that I would otherwise have taken the runners of the seat and bolted directly to the chassis to eliminate the problem. He went to see my original tester (who I think is the main guy for kits) and came back and said it was OK.
MK Owners Club Member 1015
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/7/07 at 04:32 PM Reply With Quote
Thank you for that
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/7/07 at 04:36 PM Reply With Quote
ok, so i think general thoughts are seatbelt height so i will go ahead and take the runners off and that will hopefully lower the seats enough? also the nuts on the filter, so i'll need some silicone.
<<  1    2  >>
