Author: Subject: 1999 ZX9R
matt.c
posted on 26/7/07 at 07:04 PM Reply With Quote
1999 ZX9R
Just a few questions for you all:
1. Which filter and jet kit is needed
2. Sump modification/baffled/chopped
3. Clutch plates/springs etc
4. Where are the best places to get the above items.
Many thanks.
Wadders
posted on 26/7/07 at 07:10 PM Reply With Quote
Hi.
Any foam filter and backplate will do, mines pipercross. TTS also do them Dynojet kit to sort the fuelling, and then ideally a R/R session to fine tune.
Sump needs chopping and the drain plug moving to the side, shortened pick up strainer and a baffle plate. Chris gamlins uncle chops them nice and cheaply. other option is a billet sump. but they cost a few hundred quid.
Standard clutch plates with heavy duty springs. TTS sell them amongst others.
Al.
Many thanks.
matt.c
posted on 26/7/07 at 08:01 PM Reply With Quote
Cheers wadders.
My engine has the standard clutch plates, do i have to add any more plates?
Regarding the springs, can i get these springs from kwak, if so what are they off?
Andy W
posted on 26/7/07 at 09:18 PM Reply With Quote
Hi
Try barnet springs with standard plates.
you can get away with mods to the standard airbox if you have a bonet bulge
Chopped airbox
Chopped airbox
matt_gsxr
posted on 27/7/07 at 04:33 PM Reply With Quote
Andy,
don't forget to install your manifold/headers!
Matt
