Author: Subject: has the sump got to be chopped
Chris7
posted on 31/8/03 at 09:54 PM Reply With Quote
Hi
i am building a book built locost and would like to know if i have to chop the sump on ZX9R Engine .
Jon Ison
posted on 31/8/03 at 09:58 PM Reply With Quote
in a word, yup. Two or three on here have done it so they will point you in the rite direction.
Chris7
posted on 1/9/03 at 07:17 AM Reply With Quote
update
Hi
Is the reason for this that so there is more ground clearance, or if i mount the engine higher will this not have to be done
the reason i ask is that if kawasaki wanted the sump chopped they would have chopped it does it run as good with this modification .
any help much appreiciated .
Chris7
posted on 1/9/03 at 12:08 PM Reply With Quote
Got a solution to chopping sump
Hi
Found some bodywork from Leugo which is 2inch higher than normal body work for locost which should take care of the problem of having the sump chopped .
Thanks Chris
posted on 4/9/03 at 07:00 PM Reply With Quote
Mistral chopped mine,put the drain on the side, modfied the pickup, supplied a baffle and new gaskets.
Well worth the 150 notes if your worried about it hanging down as it does!
ChrisGamlin
posted on 4/9/03 at 07:15 PM Reply With Quote
Its mainly only done for clearance benefits, with regular Locost bodywork you'll struggle to get it under the bonnet and not be virtually dragging the ground without a sump chop. Whilst its being chopped you can also have a few baffles added which will help keep oil around the pickup in a BEC installation, so there are other benefits too.
If you need it done then gimme a shout as my uncle has done several ZX9's now, including Jaspers, for £50 including modding the pickup, putting in baffles and putting the drain plug on the side.
I think Jasper has some pics in his gallery if you want to have a look.
Chris
tadltd
posted on 4/9/03 at 11:08 PM Reply With Quote
Stuart Taylor do billet machined sumps for the ZX9. I think they're about £120 (check their web-site for details).
But it sounds like Chris' uncle is your best bet if your counting the pennies!
Steve.
Chris7
posted on 5/9/03 at 08:47 AM Reply With Quote
Sump
Hi
Cheers for that info i will see when its ready for fitting i need to make the sump smaller i think i will speak to jasper if is uncle knows his stuff will be well sorted .
ChrisGamlin
posted on 5/9/03 at 08:54 AM Reply With Quote
Just to clear up the confusion, it wasnt Jasper's uncle, he got his sump done thru John, MY uncle .
Chris
[Edited on 5/9/03 by ChrisGamlin]
Jasper
posted on 5/9/03 at 06:47 PM Reply With Quote
And a very nice chap he is too! Will make up other nice ali bits for you as well if you ask him nicely and grease his palm.
