Author: Subject: Propshaft angle? BEC
garage19
posted on 21/4/08 at 02:04 PM Reply With Quote
Do you front engined BEC guys mount the engine with the output shaft directly inline with the diff input?
If so this means that the engine is quite far over in the nearside of the engine bay??
I am about to drop a zzr1100 engine in my brother in laws chevette and am just wondering if i can centralise the engine to help with exhaust clearance and run the first part of a two piece prop at a bit of an angle instead of straight??
matt_claydon
posted on 21/4/08 at 02:08 PM Reply With Quote
Nothing wrong with an angled propshaft, as long as the sprocket adapter and diff input flange are perfectly parallel. I believe most BECs have the engines well over to the passenger side.
Plenty of photo archives here to check out!
garage19
posted on 21/4/08 at 02:11 PM Reply With Quote
I know you are supposed to run them a few degrees off to help the bearings but how many degrees max?
Can anyone point me to any photos?
posted on 21/4/08 at 02:21 PM Reply With Quote
I don't know about the max angle, but I have seen 3 degrees as a recommended value.
garage19
posted on 21/4/08 at 02:36 PM Reply With Quote
Sorted that engine yet David? I could do with a ride in a locost to get my enthusiasm for mine back.
matt_gsxr
posted on 21/4/08 at 02:37 PM Reply With Quote
popular question!
link
My conclusion from all that is:
1) Make face of diff parallel to face of prop-adapter.
2) Put diff to centre bearing perpendicular to diff.
3) Minimise the angle if you can, but 5degrees is alright.
Generally your degrees of freedom when putting the engine in are pretty limited. What I mean is the height is fixed, and the exhaust manifold to top-rail is always a worry.
Oh! just re-read the question, I guess top-rail isn't an issue! Make sure those headlamps don't fall out though, I used to have one of those chevettes (first car)
Matt
posted on 21/4/08 at 03:18 PM Reply With Quote
Very, very, VERY nearly!
Just got to assemble the filter box and spray some VHT paint on the exhaust manifold where I've welded the sensor boss.
I may be bothering you very soon...
ReMan
posted on 21/4/08 at 05:16 PM Reply With Quote
Chevette!
Is it Fibreglass?
850kg standard, how much can you get it down too?
V8's are more common in those
ChrisGamlin
posted on 21/4/08 at 06:44 PM Reply With Quote
This is mine, not set up with a huge amount of science because I was restricted to where I could put the engine, but works fine.
Prop Angles
Prop Angles
Coose
posted on 21/4/08 at 07:43 PM Reply With Quote
+/-7 degrees per UJ. Make sure that the UJ's aren't straihgt as this will cause flats to wear on the UJ bearings. Also, I don;t think it's *that* critical that the flanges are perfectly parallel - they never are on a live axle set-up!
Spin 'er off Well...
Jon Ison
posted on 21/4/08 at 08:37 PM Reply With Quote
My engine runs parallel to the chassis rails so the output flange and diff flange are far from parallel.
7 years & 15k (recorded) hard miles later no problems to date.
