Author: Subject: VAG transaxle drawings
irvined
posted on 11/7/09 at 03:31 PM Reply With Quote
Does anybody have any drawings or measurements from the VAG transaxles ie as fitted to the passat?
I'm toying with using one of these as part of a midi project, if not the drawings, rough dimensions and mating faces would be ideal if anybody has them around.
http://irvined.blogspot.com
meany
posted on 11/7/09 at 04:13 PM Reply With Quote
I dont, but you could ask my old school mate.
http://www.awesomegti.com/
Fred W B
posted on 11/7/09 at 04:59 PM Reply With Quote
If you are talking about older passats that used the 016 trans, I have measured the bolting pattern. Let me know an e mail adress and I can send that to you
Fred W B
bram boekestein
posted on 11/7/09 at 06:25 PM Reply With Quote
Here you go: 016 dimensions gallery
I've started today on making a 3d model in solidworks from a 016, but still taking dimensions.
If you need any dimensions just let me know.
If it was from a passat it would proboarly be an 012. I have the exact bolt pattern from that also, other dimensions I have to look for.
Bram
nasty-bob
posted on 11/7/09 at 10:08 PM Reply With Quote
I've got a model (rough) based on the same drawings Bram posted but also with the bolt pattern and tweaked to match the 012 from the Audi A4 and VW Passat.
It you want it let me know an email address and the format you want- stp, CATPart, slwprt, iges, etc
Rob
[Edited on 11/7/09 by nasty-bob]
