Author: Subject: Waterjet Cutting
liam.mccaffrey
posted on 30/4/18 at 03:06 PM Reply With Quote
Waterjet Cutting
Ladies and Gents I'mm looking for a recommendations for waterjet cutting services for the following set of plates.
I'm in south west wales and already have tried some localish vendors. The material is 5mm mild steel which I can supply if it makes difference to the price.
For reference the holes are 12mm.
Anyone have any idea how much this is likely to cost as I'm still waiting to hear back from the folks I've contacted already.
Thanks in anticipation.
Liam Mc
brackets
brackets
Build Blog
Build Photo Album
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
posted on 30/4/18 at 03:23 PM Reply With Quote
No experience with water jet cutting. The sheet metal people we use at work use the laser process. Might be another option for you to investigate - many will work from a CAD drawing, but many will also have a minimum charge (think setup fee).
loggyboy
posted on 30/4/18 at 03:31 PM Reply With Quote
I got 4 plates cut (Hub spacers) by a chap on here (andyw7de) and it was 28 for 2x 10mm and 2x 20mm, in ally, that he supplied. Was 6 years ago so no idea if prices have changed or if he is still doing it.
obfripper
posted on 30/4/18 at 03:47 PM Reply With Quote
http://www.precisionwaterjet.co.uk/
They are local to me, stock alot of materials and were v.competitive on price the last time i used them.
If you use their contact form you can attach the .dxf drawing and they will price up the material of your choice.
The last things i had done were in 6mm 6082 t6 aluminium and was 70ish including materials, approx sizes 1x 150x300mm, 1x 80x300mm, 3x 60x150mm.
Dave
DanP
posted on 30/4/18 at 08:29 PM Reply With Quote
If it helps, laser or plasma will also happily cut those shapes, so you may be able to find a cheaper supplier.
At 5mm plasma will give a pretty good cut, the cuts in the pic below were done with a 45A Hypertherm (CNC) on 5 and 8mm steel:
Plasma
Plasma
Ugg10
posted on 30/4/18 at 09:51 PM Reply With Quote
I used a company down in Cornwall that did laser cutting, they were pretty go and do steel and aluminium, just send them a Dxf/dwg and they will get back with a quite. The manifold plates and plates for engine mounts were cheap enough for it not be worth getting the jigsaw and drill out.
https://www.lasermaster.co.uk
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
liam.mccaffrey
posted on 1/5/18 at 08:12 AM Reply With Quote
Thanks for all the advice guys,
I decided to go with my local supplier http://www.crosswaterjetservices.co.uk/
They came back with 60 (72 with VAT) for the parts which I am more than happy with.
[Edited on 1/5/18 by liam.mccaffrey]
Build Blog
Build Photo Album
coyoteboy
posted on 1/5/18 at 01:03 PM Reply With Quote
Bit late but I've used northwestwaterjet.co.uk for a big crankshaft tool - came in at a good price and worked from CAD no problem. Good folks to deal with.
Report your local potholes, it actually works!
Benzo
posted on 2/5/18 at 10:11 AM Reply With Quote
My local machine cost 2 a Minute to cut, you can up the cut speed to make it cheaper but quality of the cut reduces with speed.
only really an issue with heavier material.
[Edited on 2/5/18 by Benzo]
