Author: Subject: engine trouble?
bikkel
posted on 11/3/07 at 10:01 AM Reply With Quote
engine trouble?
Hi all
Blue-ish smoke coming from the cam/rockercover on my ZX12(venting
hose to catchtank)at medium-high revs not on idle.
-crankventilation = blocked off
-drysump system installed
what migh be the problem?
i might have overrevved the engine a bit during a testdrive., not sure.
anybody got a clue?
thanks
koen
www.zx12r-indy.tk
thunderace
posted on 11/3/07 at 10:09 AM Reply With Quote
too much oil i think.
dilley
posted on 11/3/07 at 10:20 AM Reply With Quote
You cant over rev with a rev limiter, I have a dry sump installed and I have connected the crank breather and rocker breather together at the tank.
bikkel
posted on 11/3/07 at 10:23 AM Reply With Quote
hi
-I might have overrevved it ruring a downshift.
- drysump= no overfilling
koen
www.zx12r-indy.tk
mark chandler
posted on 11/3/07 at 02:03 PM Reply With Quote
Dry sump should provide negative pressure in the sump so you should not see anything venting at all if everything is working properly.
Sounds like tired or stuck rings creating excessive crankcase pressue to me, was it sitting about for a long time ?
Regards Mark
bikkel
posted on 11/3/07 at 04:58 PM Reply With Quote
yes mark,
engine has been standing still for longer period.
what rings are you referring to?
piston rings?
koen
[Edited on 11/3/07 by bikkel]
www.zx12r-indy.tk
