Author: Subject: luego velocity ( mts75 and sierra dif ) - prop length?
saigonij
posted on 10/8/07 at 01:42 PM Reply With Quote
Can anyone tell me the length of the prop i need...
I have a zetec ( not really important ) mated to an MT75 which is bolted on using the standard ford gearbox mount to the standard velocity chassis mount.
at the other end im running a 7inch DIF also mounted on the standard velocity mounts...
so,,,,,
anyone tell me what length i need?
Ian
[Edited on 10/8/07 by saigonij]
Sebastian
posted on 10/8/07 at 02:45 PM Reply With Quote
I would measure it myself when everything is in place, just to be on the safe side.
And then order it at Baily Morris, i believe that they have a drawing of a propshaft where you can put the dimensions in.
You could also look at the post below of a propshaft for a Velocity for sale.
Sebastian.
saigonij
posted on 10/8/07 at 02:55 PM Reply With Quote
the post for sale is for a type 9 box not an mt75
jollygreengiant
posted on 10/8/07 at 04:02 PM Reply With Quote
You will have to measure your set up as all the builds are different. I saw the one advertised & thought yep that would do, BUT, when I measured my car I found that the I needed one that was 635mm. So 690 was toooooo long.
Some how I have managed to get my gearbox about 3 inches further back than most people.
Enjoy.
